97 5 spd fed spec ECU into a 99 cali spec car
Old Sep 6, 2011 | 10:22 PM
Roosky's Avatar
Ok fellas, heres the deal. Doing a 5 spd swap into a 99 cali spec car. I've done swaps before, and I know that i can run the auto ECU just fine, with the exception of a higher idle and a CEL, but i got a 97 fed spec 5 spd laying around that i was thinking about putting in. What are the consequences? I'm guessing a bunch of emissions related codes. What else? I could live with a CEL on for a while, since we dont have emission in florida, but would like to get rid of the light sooner or later and have the idle where it's supposed to be. Should i try and source a 5 spd cali spec ECU? If i do, i'm guessing it would have to be a '99, because of the immobilizer, which leads me to believe if i put the '97 ECU in, I wouldnt even be able to start the car because of that. Looks like my best bet would be just to keep the stock auto ECU and deal with the higher idle. What do you guys think? Any input is appreciated
Old Sep 7, 2011 | 07:40 AM
asand1's Avatar
97 doesnt have immobilizer so no worries there. People swap to older ecu to be rid of it. That's all I know on the subject. I think you will have to swap a few wires in the harness plug. Codes should not be a problem, the car will have the required sensors and then some but the ECU wont care and wont turn on the light. I could be wrong.
Old Sep 7, 2011 | 08:54 AM
MAXIMA_STYLE's Avatar
CALI equipped cars have stricter emissions such as precats and an extra o2 and swirl valves all of which prevent the car from polluting the air before up to operating temp... so a fed spec ecu may work but youre going to throw codes for the extra o2 that wont be reconized as for the swirl valves also, easy way around that ....replace lim with fed one and ypipe and front manifold from a fed car...the rest....i woulnt worry abou right now
Old Sep 7, 2011 | 09:18 AM
asand1's Avatar
97 Fed spec ECUs "which he wants to use" dont look for a 4th O2, or swirl valve. Therefore, the ecu will not throw a code for it. The only problem I see is a non functioning swirl valve.
Now, if someone installed a 99 cali ECU in a 97 FED car, you WOULD have codes.
Old Sep 7, 2011 | 10:20 AM
Roosky's Avatar
thanks for all the replies guys. whats a swirl valve and what does it do?
Old Sep 7, 2011 | 12:20 PM
ajm8127's Avatar
I believe on a 99 the Crank REF signal comes in on pin 46. You will need to change it to pin 44 to make the car run. Also, the O2 sensor signals are in different places. The 97 will be looking for the Fuel pump control module as well, which does not exist on a 99. I would find a Cali spec 99 manual ecu if I was you. If you want to go down the difficult road, check out the file I have attached.
A32 ECU connector cross reference.pdf
Old Sep 8, 2011 | 06:26 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
took all my cali spec nonsense out you dont need it :-)
Old Sep 11, 2011 | 04:14 PM
Roosky's Avatar
would you care to elaborate on that? as far as what you took out and what you swapped in. thanks
Old Sep 11, 2011 | 09:10 PM
Roosky's Avatar
just for the record. 98 fed spec manual ecu wont start your 5 spd swapped 99 cali spec max. why? i dont know
Old Sep 11, 2011 | 10:44 PM
skylinemax82's Avatar
i have a 97 maxima se fed 5spd, and i have to use a 96 nissan maxima se fed 5spd ecu in order to have jwt re program it for me, whats different?????
Old Sep 12, 2011 | 08:43 AM
Roosky's Avatar
i guess cali ecu is pinned different from the fed one, but like i said the car wouldnt even start. popeed the cali one back in and all is good
Old Sep 12, 2011 | 08:54 AM
ajm8127's Avatar
Probably because of the difference in the pin out on the ECU connector for the Crank REF sensor.
Old Sep 12, 2011 | 09:05 AM
maxboy325's Avatar
ajm8127 has your answer.
Attachment 2283
Hey Tony.
Old Sep 12, 2011 | 12:06 PM
ajm8127's Avatar
Originally Posted by maxboy325
Hey Tony.
Hi Dameian, hows everything going?
Old Sep 12, 2011 | 01:19 PM
Roosky's Avatar
but the diagram you linked says its the same for crank REF sensor on all years, o2's on the other hand are all different, but that wouldnt prevent the car from starting, would it? btw thank you for being helpful
Old Sep 13, 2011 | 01:02 PM
maxboy325's Avatar
All is well. I will be contacting you soon.
I did not read the the link posted but I do know the pin out for crank is different on the 99 REF AND POS I believe
Old Sep 22, 2011 | 09:33 PM
Roosky's Avatar
Attachment 2283
I dont mind repinning the harness, but i wanna be a 100% sure it'll work. On the diagram you attached the cranck sensors are on the same pins on all years, thats what got me confused. Is the pin 46 to 44 info from your own experience? Again, thanks for all the help guys
Old Nov 10, 2011 | 04:15 AM
Im bumping this cause im in need of an answer to this as well i got a 99 with 97 fed spec engine and need info on the ecu pinout
Old May 12, 2012 | 08:02 AM
Wow no one has an answer to this??
Lakersallday24
Jun 16, 2019 01:35 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MikesChevelle
Aug 14, 2015 12:31 PM
Supragte
Aug 12, 2015 10:00 PM
1992maximase30
Aug 5, 2015 09:27 PM
