restoring headlights
Old Nov 9, 2012 | 03:09 PM
  #41
GGENIUS's Avatar
Look great. Thats how I did my dads 5th gen HL's. Sand and clear. Really the only semi-permanent method as long as you pay them attention every car wash. Yet another reason the 95'-96' is better....Mine dont need all that
true but arent they less clear to begin with?
Old Nov 9, 2012 | 05:06 PM
  #42
ShocknAwe's Avatar
yea they arent very clear at all and dont look good. I like them simply because they are built to last. With Silverstar bulbs they put a hell of a lot of light on the road.....just dont look very good.
Old Nov 9, 2012 | 07:04 PM
  #43
GGENIUS's Avatar
im wonderin what the output looks like with projectors.
Old Nov 12, 2012 | 12:52 PM
  #44
hacim105's Avatar
Hear are my results, I wetsanded with 800 grit. Clearcoated with a rattle can. Wetsanded with 2000 grit and polished. Wetsanded with 2000 grit again (still some orange peel look to it, but the 2nd sanding took it away) and polished one final time.
800 grit wetsand
Clearcoat ---> 2000 grit ---> polish
2nd 2000 grit ---> polish (apparently I didn't do a great job the first time)
Old Nov 13, 2012 | 07:24 AM
  #45
jake0330's Avatar
damn they came out good, I'm going to have to attempt this
Posted from Maxima.org App for Android
Old Nov 13, 2012 | 08:01 AM
  #46
jholley's Avatar
Originally Posted by GGENIUS
no idea but i think it should be good. its DuPont 74700s.
Did you use the 2:1:1 ratio (clearcoat : hardener : reducer) when mixing the 74700s? With plastic headlights should I use less hardener to keep them from cracking? 4:1.5:2
Old Nov 13, 2012 | 04:00 PM
  #47
GGENIUS's Avatar
yes that is the ratio i used, with all dupont. and no, mix it correctly, there will be no problems with cracking. ive gotten the same results with sherwin williams clear too, just as long as its automotive grade clear.
Old Nov 13, 2012 | 06:51 PM
  #48
jholley's Avatar
I'll try the 2:1:1 mixing ratio after I wetsand the headlights, corners, and foglights with 800. I just got new clear bumper lights delivered today so I'll wetsand those with 1000 then clearcoat them also so they blend good with those other lights.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Oct 25, 2015 02:47 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Noela
Sep 26, 2015 08:22 AM
