Rear brakes over-heating...
First and foremost, I researched this common 4th gen problem, and could not find my answer.
Last year I replaced both rear calipers with rebuilds. They worked perfectly until March when the drivers side caliper began to stick. I found out that it was the spring mechanism that returns the parking brake cable, so I recently bought a new caliper and swapped it out. I now have BOTH rear rotors getting very hot during a trip (about as warm as the fronts), when before I could always touch them after a drive. The car seems to roll fine when I'm stopped at a light on a slight gradient, but once moving they feel hung up a bit.
I tested the e-brake cable when I was swapping the caliper and it works perfectly. No damage, and goes back and forth with no resistance.
I also bled the brakes, but may have to do this again because the pedal is a bit spongy.
Could something weird be going on because I have a new caliper with a slightly used one on the other side?
Yeah, I should have added that too. The brackets and pins are new with fresh grease. One other thing I am thinking is that the line may be pinched where it connects to the caliper. There is a groove it sits in that was a tighter fit with the new caliper. I may inspect this tomorrow. Would a line pinched on one side of the car cause both rears to drag? That doesn't sound right to me.
You could crack the bleader on the offending caliper(s) for a split second to relieve any residual pressure. If this frees up the caliper it would indicate a hydraulic issue; kinked hose, hose degrading inside (flap acting like check valve), bad proportioning valve, ABS, or MC.
BEWARE, THIS WILL MOST LIKELY REQUIRE BLEEDING THE BRAKES AFTERWARD!!
