DEK Swap
Old Sep 20, 2011 | 10:45 PM
NotoriousMaxx98's Avatar
DEK Swap
Hello!
I have a 98 VQ30DE 5spd and the motor locked up on me SMH. But now I want to do a swap for a DEK. I have spent plenty of times in the search bar. Some questions have been answered and some threads were just confusing. I no I would need to splice dek injectors. Do I need to splice the coil packs too? Plus, how would the motor go if I were to delete the EGR valve all together?
Since we talking about it what is all needed to complete this swap? No Codes
I thought about the 3.5 but I work 5days out of the week and parents being my transportation SUCKS (Im 18 BTW). I need my car and money is tight. Im trying to save for school.
Thanks!
Old Sep 20, 2011 | 11:07 PM
beegeezy's Avatar
If money is tight why bother swapping to a dek? If you are going to do all the work yourself (let's face it, you're 18...you're going to mess something up) maybe it's worth trying. It would be much easier, faster, and cheaper to just get another de engine. It might be more reliable too. (until you got the kinks out of the dek swap)
Old Sep 20, 2011 | 11:14 PM
No sir!!! I dont have the patience or time to do it myself. Im trying to gather info to see what I need for the dek or say forget it and do another de swap
Old Sep 20, 2011 | 11:22 PM
beegeezy's Avatar
Are you going to get some buddy to do it? Otherwise why gather info if a shop is going to do the swap? Any decent mechanic can do a dek swap. (I said decent)
You could just get a low mileage dek, use the block/head/whatever else is directly compatible, and then sell off the 00VI to help offset the cost.
Old Sep 20, 2011 | 11:26 PM
mista0406's Avatar
DE-K Swap (entire engine swap) will need:
1) EGR block off plate (if your going that route) if not a new 5th gen EGR Tube
2) Throttle cable plate made (cause the 5th Gen has longer cables)
3) Fuel injector plugs spliced in
4) IACV adaptor plate unless you want to try your luck with the 5th gen one
5) Of course all new gaskets(throttle body, egr, valve covers, intake manifolds, etc,etc)
6) injectors coilpacks from a 5th gen
7) also an rpm switch to activate the VI
And as far as the coilpacks go no you do not need to splice them in.
If I missed anything just add it
hope this helps
Old Sep 20, 2011 | 11:28 PM
mista0406's Avatar
This is also very true^^^^^
Old Sep 20, 2011 | 11:32 PM
I live in the DMV area and there are a few people that can pull the job in their garage. I mean I would like to know what goes on myself. I'ma a up coming mechanic. Trust if I had nothing to do I'll pull this job myself with a hand from another car geek and you guys
Old Sep 20, 2011 | 11:40 PM
beegeezy's Avatar
Plenty of good info in the all motor section. The cliff's version is that a dek swap is reliable if done properly. If you are really on a budget try to do a straight de exchange. Less work is less money when it's all said and done.
Old Sep 20, 2011 | 11:50 PM
You have a point. I wanted to do a 00VI on my motor until this tragic happened. So why not just do the dek swap. Just what I was thinking. Yes I'm saving now but I can also save by doing the dek now instead of the 00VI later.
Old Sep 21, 2011 | 07:19 AM
cashoit's Avatar
check tha all motor section or SEARCH. There is a how-to and written instructions to do the 00IV swap.
The cheapest and easiest way to get back on the road is to buy another low mileage DE motor and swap it in.
Dont get me wrong, the 00VI mod is cool but there are so many other performance mods that u can do before getting to that point.
And if u cant do the work yourself, then get a mech to swap in the DE and be done with it. No mech will guarantee the DEK swap for u
Old Sep 21, 2011 | 08:26 AM
I found a de for $675 with a 6 month warranty Ill just do that.
Old Sep 21, 2011 | 09:07 AM
wirelessdude04's Avatar
Good luck. Just remember if you have a doubt in your mind about something search before you do it
Old Sep 21, 2011 | 02:20 PM
MaximaSpd85's Avatar
buying another DE will be the silliest thing you could ever do. First, what is a low mileage DE? Second, even if you just want to use the block you can sell the 00vi stuff and come out cheaper than just buying a DE.
A DE for 675?? Is that what they go for in your area? DEKs go for $450 at the local salvage yards here, so maybe look into that price a little more. A DEK is as close to a direct swap that you can ever have aside from minor wiring, and using your own sensors. seriously.
Old Sep 21, 2011 | 07:03 PM
Really?!?!?! I saw a DE for $450 but the milage was 136K. Prices out here, are too much for a good motor
Where are you located?
Old Sep 21, 2011 | 07:09 PM
beegeezy's Avatar
Before this goes any further go TALK to a mechanic and get a quote on both jobs so you can compare. Everyone telling you to just do the swap is speaking from a diy point of view...which you are not doing. The cost difference between engines is negligible at best. Find out what the rest of the job will cost and THEN decide what to do.
Old Sep 21, 2011 | 07:18 PM
wow. im located in north carolina. i figured with the way those dcmax boys do swaps that they were a lot cheaper there. ive purchased 3 deks here, for 3 different swaps, and they were all the same exact price- $450, all with around 80k miles. 3.5s on the other hand are around $675 from what ive seen.
Old Sep 21, 2011 | 10:36 PM
That's crazy I wish I can find a dek for $450 with 80k or less.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
