00vi w/ 4th gen IACV COLD hard start
Old Sep 24, 2011 | 08:54 AM
hornepirate's Avatar
Wondering many of us with an 00vi using the 4th gen IACV are having a hard cold start and i DONT mean engine sitting overnight cold. I mean when the ambient temperature is below 50 degrees cold.
If you have the issue state how you deal with it.
Old Sep 24, 2011 | 10:30 AM
ampire's Avatar
With the IACV adapter on my 3.5 I had to start the car, usually took a few cranks and then keep the gas pedal depressed a bit for about a minute before the idle got up to a constant 900 rpm without dying. After that it was smooth sailing. This was in 20 degree weather last winter. Subsequent "warm" startups like an hour later were much easier since it was warmed up.
Old Sep 24, 2011 | 12:03 PM
MOHFpro90's Avatar
Hard cold start meaning extended cranking? Might want to make sure your IAC is actually working.
Old Sep 24, 2011 | 01:03 PM
malamgir85's Avatar
I had the same problem. changing the fuel filter took care of it
Old Sep 24, 2011 | 01:40 PM
Well fuel filter is new and cold starts when temps are above 50 starts first turn but when outside temps are low i have tp do what amprie said crank one or twice and hold my foot on the gas while i crank to turn it over.
Just wondering if anyone found a cure for that
Old Sep 27, 2011 | 11:16 AM
bump
02PearlSE
Oct 7, 2015 02:12 AM
Finkle
Sep 27, 2015 09:53 PM
schmellyfart
Sep 25, 2015 04:47 PM
95Maxi
Aug 25, 2015 08:01 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
