I need your opinion
Old Sep 24, 2011 | 08:41 PM
rf97's Avatar
I need your opinion
Ok, so I bought new monroe front struts to install, but after failing to complete the install my self, I'm tempted to buy the complete set up from ebay(complete strut and spring assembly). My question is has any one on this forum used any of them and are they any good? I see two listings for the complete front for under $200.
Old Sep 24, 2011 | 08:50 PM
TurboA32's Avatar
dont know about monroe but you should of got some kyb's
Old Sep 24, 2011 | 08:57 PM
augnon's Avatar
I bought 4 quick struts from rock auto and I'm happy with them. Just plug and play.
Old Sep 24, 2011 | 10:45 PM
Bassman.357's Avatar
when i 1st got my car, my dad got a discount from pepboys on some Monroe shocks/struts for my car, their decent if you want to keep things OEM, i haven't had any trouble with them
what kind of issue did you run into?
Old Sep 24, 2011 | 11:01 PM
QT1 5MT AE's Avatar
Gram Lights addict
why did you fail to install them yourself?
Old Sep 25, 2011 | 02:46 AM
max ride 41's Avatar
this thread fails, learn how to search
Old Sep 25, 2011 | 06:16 AM
rf97's Avatar
MAX, why do yo say the thread fail? I'm not asking an opinion of which strut works best as far as ride quality etc. I'm try to find out if anyone use any one of these below. I failed to swap out the struts because I couldn't get off the center nut that holds the spring to the strut, for some reason the strut thats on there has no where to clamp on to, to keep the center piston from turning when unscrewing this nut.. Everything on the car is stock, just looking to keep the original ride quality, just don't want to install something that's not going to hold up.
Old Sep 25, 2011 | 09:04 AM
QT1 5MT AE's Avatar
Gram Lights addict
first you need to rent a spring compressor from autozone and compress the spring before even attempting to remove it from the shock. this is a very important saftey precaution.
then use a vice grip on the center piston to stop it from moving. it has to bite super hard to work. thats when u can loosen the nut. Done it myself.
Old Sep 25, 2011 | 12:30 PM
Originally Posted by QT1 5MT AE
\you need to rent a spring compressor from autozone and compress the spring before even attempting to remove it from the shock. this is a very important saftey precaution.
you can use 2 8in' C-clamps, (not really recommended for beginners or novices) and it'll do the job, in your case...i'd get the spring compressor............, make sure your compress the springs when the car, is on the ground, not when it's being jacked up. a job like this, it def. doesen't hurt to have a spotter, you never know when *ish* fails and starts to hit the fan...or your for that matter.
also in relation to the center pistion, you should be able to get a socket to unlock it, that nut or ring (i can't remember) should be broken 1st before you jack up the car.
how me and my dad did this in order
- center piston ring/nut
- compress spings with car on ground
- secure & lift car
- brake 2 shock absorber bolts
- brake the 3 nuts on the top plate of the strut/shock
- remove the 3 nuts from the top plate
- remove the 2 long bolts from strut/shock
and its out.
Old Sep 25, 2011 | 01:23 PM
gerber2022's Avatar
well i bought the moog strut from ebay and they are great and get some tokico shocks might as well do it only once
Old Sep 25, 2011 | 01:46 PM
Shift_A32B's Avatar
I replace my front struts with Monroe complete assembly from Amazon. Direct fit, no hassle. Awesome ride quality. It has been months and no issues.
Old Sep 25, 2011 | 06:13 PM
rf97's Avatar
thanks guys, I just ordered the complete Monroe Econo Matic setup from rock auto, I'll let yawl know how they ride after installing.
Old Sep 25, 2011 | 06:24 PM
tigersharkdude's Avatar
y'all now yawl
Old Sep 26, 2011 | 08:00 AM
bobflood's Avatar
+1 on this. Got mine from Advance Online with in-store pickup to eliminate shipping. Put all four corners on almost two years ago and they have been fine.
Old Oct 6, 2011 | 12:03 PM
rf97's Avatar
Just installed the complete strut and spring assembly I bought from rockauto this past weekend. My car now rides much better, although it looks like these new springs are a bit softer. I need to go get a front alignment, my tires are screeching when I go around corners, this is because I need an alignment right?
Old Oct 7, 2011 | 12:02 AM
ummmm, yeah. that would help
REDinLV
Aug 15, 2024 12:30 AM
dvcamp
Sep 18, 2015 10:17 AM
ac max 92
Sep 17, 2015 07:35 AM
