The A32 Parts Cross Reference Thread
This will take probably years to finish, but we have to start somewhere.
Same Parts across the whole generation:
-Front Crossmember
-Rear Transverse Link Assembly
-Power Steering Resevoir
-Windshield Washer Resevoir
-Front Windshield
-All Door Glass, regulators and motors
-Quarter Glass
-All Doors
-Horns
-4AT Transmission (Exactly the same if you get the same options for them, eg 96 4AT w/ LSD = 99 4AT w/ LSD)
-Struts+Springs: GXE and GLE
-Struts+Springs: SE =/= GLE/GXE
-Brake Rotors
-Brake Calipers
-Maf
-Brake booster
-Radiator (The same for all years, minor difference for the transmissions, AT has extra inlets for the AT cooler, and MT does NOT have the inlets)
Different Parts:
-AC Compressor... This one is amazing, I've personally verified that there are 2 A/C Compressors from 4th gens that will NOT fit on my 99 made in 3/99... And my computer says there are 4 different part numbers for 95-99... -__-;;
-Headlights: For the 97 refresh they changed the lens to a plastic clear lens, instead of a glass fluted lens
-Corner Lamps: In 97 they rewired the corner lamp so it no longer brightens when you use the turn signal
-Air Intake Assembly: 95-96 The same, 97-99 Different (PART NUMBER WISE) [Needs verification]
-Power Steering return line (low pressure side): The 95-96s have an extra loop that goes in front of the radiator for some sort of cooling, the 97-99s do not.
And so on... and so on... Add as you may like but please add some sort of verification link or photo.... Unless it's glaringly obvious.
-Front Crossmember
-Front Windshield
-Quarter Glass
-All Doors
-Horns
-Brake Rotors
-Brake Calipers
-Maf
-Brake booster
Different Parts:
intake: 95-99
wheels: 95-99 SE, GLE, GXE
motor components(not sure, just throwing it out there)
radiator: 95-99
95/96 exhaust =/= 97-99 has a S pipe
radiator: 95-99
MR2 T'd
07-09-2021 05:06 AM
