starting troubles again
when i bought my max half a year ago it had starting issues. sometimes it started perfectly fine while other times i didn't get any reaction from turning the key until the 2nd or 3rd turn. i replaced the ignition switch and everything seemed fine after that, but recently the same problem has come back
i remember reading about people facing the same scenario but i don't recall what they did or where i could read it again. does anyone know what i should do?
What people have done is to remove the ignition switch and insert a small piece of duct tape in the slot where the key goes into it. This causes the ignition switch to get turned a little bit more. It is not a guaranteed fix. It works for some but not for others. You may still need a new ignition switch as BobFlood suggested.
If you do this, don't use a giant piece of tape as it can jam.
Check out this link, specifically the photo in post # 36.
http://forums.maxima.org/4th-generat...start-car.html
mine turned out to be the starter, thought it was the ignition switch did the 'fix' but it would continue to have problems, more and more frequently. Finally changed out the starter and no problems since then.
bryants95max
Oct 2, 2015 12:52 PM
QueensMAX
Sep 15, 2015 04:14 AM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
