rotating motor manually
Old Nov 8, 2011 | 10:10 PM
918noah's Avatar
Ok I have been serching for a while now and have seen both answers. If I am changing out tensioner and guide which way do i turn crankshaft pulley? clockwise or counter? thanks for help
Old Nov 9, 2011 | 06:44 PM
918noah's Avatar
Nobody on here know which is the correct way to turn the motor?
Old Nov 10, 2011 | 01:10 AM
Trini Boom's Avatar
You have to turn clockwise only. Counter-clockwise and that's a big risk!
Old Nov 10, 2011 | 07:38 AM
martyscholes's Avatar
Why are you turning the shaft to replace a tensioner? Turning it clockwise will add slack where the tensioner is located and tighten up where the water pump is located. Counterclockwise does the opposite.
Too much of either (more than 30-ish degrees) and you might develop enough slack on the crank sprocket to slip a tooth, which certainly would ruin your day.
Old Nov 10, 2011 | 09:51 AM
Snypa's Avatar
to tha right.
Old Nov 10, 2011 | 10:47 AM
svezarov's Avatar
When I was changing my water pump I remember that I was suppose to turn counter clockwise to get some slack at the water pump. By turning it clockwise you can get slack at the tensioner/guides.
Old Nov 10, 2011 | 06:05 PM
918noah's Avatar
Awesome and yes that's what I will be doing tomorrow thank you for the replies.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
