confusion on fuel pressure
Old Nov 11, 2011 | 01:54 PM
smai555's Avatar
hey guys im having starting problems and i think i narrowed it down to fuel
im reading the FSM
i get about 34psi pre start and the FSM calls for 43psi
at idle im getting 32psi FSM calls for 34psi
testing the regulator it says as vacuum INcreases the pressure should DEcrease
i dont have a vacuum pump so i open the throttle from the TB creating vacuum and the pressure INcreases to about 35 psi
so its doing the opposite of what the FSM says it should does that sound right ? shouldnt it pressure increase as vacuum increase
any thoughts?
Old Nov 11, 2011 | 03:00 PM
asand1's Avatar
Opening the throttle (acceleration) results in a drop in vacuum. Highest vacuum will be at idle, or coming down a hill with no throttle.
You are confusing manifold vacuum and venturi (TB) vacuum. FPR uses mani vacuum. Direct relation to engine load, not RPM.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
