fog lights not turning on after installation
Old Nov 13, 2011 | 02:46 PM
nba0203's Avatar
so today i tried installing oem foglights on to my gxe. im pretty sure i did everything right but the fogs still dont work. i installed the oem fog light stalk, and fuse but still nothing can someone try to give me some tips to find out whats wrong
Old Nov 13, 2011 | 03:24 PM
DennisMik's Avatar
Do you have the relay (FR FOG LAMP) in the box by the power steering oil reservoir?
My car didn't come with fog lights and I don't have the relay.
Old Nov 13, 2011 | 04:20 PM
nba0203's Avatar
^^^ i put that in after i installed the stalk and foglights
Old Nov 13, 2011 | 04:48 PM
tigersharkdude's Avatar
did you get the fogs from a JY? when I got my old sset of fogs, both bulbs were blown. I couldnt the problem for anything, then I checked the bulbs.
Also, did you make all connections to the stalk?
Old Nov 13, 2011 | 05:13 PM
nba0203's Avatar
i bought them from the classifides here bulbs are piaa and the person who had them before me said they work even had pics
Old Nov 14, 2011 | 03:24 AM
DennisMik's Avatar
Since they don't light up for you, checking the bulbs seems like a logical thing to do, regardless of what the seller said. The shipping process could have broken the filaments.
Old Nov 14, 2011 | 06:10 AM
dsonnylal's Avatar
Also make sure a good 15 amp fuse is installed in the fuse box in the engine bay.
Old Nov 25, 2011 | 11:54 AM
nba0203's Avatar
could it be possible that my fogs arent wired correctly? here is what mine look like
Old Nov 25, 2011 | 02:02 PM
JNCoRacer's Avatar
Just the tip.
Uh, the white wire coming from the bulb needs to o to the red wire on the harness. The black wire is the ground and goes to the terminal on the foglight housing.
Old Nov 25, 2011 | 03:47 PM
altezzablazes's Avatar
yes they are red connect to bulb and black to the tab next to the bulb
Old Nov 25, 2011 | 04:05 PM
shook187's Avatar
How about the light switch? If the car didnt come with fogs you had the change the switch to one that has the fog switch.
Old Nov 25, 2011 | 04:23 PM
nba0203's Avatar
thanks guys ill check that out and yes ive installed everything including the fuse and switch
Old Nov 25, 2011 | 04:28 PM
nba0203's Avatar
and to JNCoRacer so the one on top is wired up right and the bottom isnt but i dont see how that would cause both of the lights to not work
Old Nov 26, 2011 | 10:02 AM
JNCoRacer's Avatar
Just the tip.
If you wired it up like the bottom pic first you might have blown the fuse or even the relay. Though Im sure the fuse would blow before the relay did. If everything is good Id get out a test meter and start finding where the break is. Somewhere between the relay to the switch to the fogs youve got power not flowing.
Old Nov 26, 2011 | 01:33 PM
99zx2's Avatar
wow, that's def. not right. the boot thingy on the black wire (ground) goes on the tab that's sticking out on the housing. the bulb wire plugs in the long rubber boot (red wire).
get a voltemeter and see if you're getting around 12v at the black and red wires.
check the 15a fuse, it might be blown.
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
