Step/Courtesy Light Help!
Old Nov 21, 2011 | 09:32 AM
Shift_A32B's Avatar
Ok, so I bought some LED lights for my step/courtesy light. My passenger door works perfect. The driver side is where I have the problem. I am 100% the bulb works, since I test it with the passenger door. Okay, so when I put in the bulb, the light is very dim (with the door being open). When I close the door, the light gets a bit brighter and stays on. Before installation, I saw a small spark in the bulb socket, so I know I screwed something up. Where should I start looking?
Thanks.
-Boris.
Old Nov 21, 2011 | 09:50 AM
max-r95's Avatar
Fuse?
Old Nov 21, 2011 | 09:57 AM
wirelessdude04's Avatar
i think this has soething to do with your BCM. Ill double check and post back when i get a chance. I dont think there is a fuse just for the step lights. Check with a multi-meter and see what your getting.
It wouldnt be a fuse if the one side is working lol
Old Nov 21, 2011 | 10:02 AM
If one side is working, it's not the fuse. The fuse for those lights is the int. ill fuse IIRC.
Try pulling your BCM fuse under the hood and reinsert it. That should reset it.
Old Nov 21, 2011 | 10:06 AM
Shift_A32B's Avatar
Thanks guys. I'll get back as soon as I find out where the BCM is at
Old Nov 21, 2011 | 10:17 AM
i should do this also being a lazy a$$ my step lights havnt worked in a year lol
Old Nov 21, 2011 | 10:19 AM
If your dome light works but the step lights don't, try resetting them with the BCM fuse. If that doesn't work, try unplugging/reconnecting your main window switch. That worked for me one time.
Old Nov 21, 2011 | 10:48 AM
CallMeThatOneGuy's Avatar
im having the same problem with the LED door lights.... i just unplugged them a few days ago
Old Nov 21, 2011 | 10:52 AM
cashoit's Avatar
naw man...its those cheap a** chinese LEDs u bought.
Had the same thing happen to me. It jus so happens that i bought 2 sets. So when the bulb was dim, i jus replace it with another one.
Same thing also happened with my dome light LED.
Old Nov 21, 2011 | 10:59 AM
njmaxseltd's Avatar
Try the refrigerator, that's a good place to look for just about anything.
Seriously, why don't you start looking where you saw the spark?
The light circuit is grounded to complete, meaning the 12v is present at all times.
Old Nov 21, 2011 | 11:25 AM
yea well I had my door panels off a few days ago installing tweeters put a multi meter to it and got no voltage at all. Im gonna try pulling the BCM fuse later and see if that helps. Not really a problem just something that bothers me lol
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
