fog lamp bulb issues
Old 11-26-2011, 08:46 AM
ncmaxvq's Avatar
Bought a 97 Max with OEM fog lamps and when i purchased it the pass side fog lamp was blown. I replaced both bulbs with yellow h3's. The pass side bulb only lasted 2 days.... bad bulb or should i be looking for a wiring issue? thanks!
ncmaxvq is offline
Old 11-26-2011, 01:35 PM
99zx2's Avatar
try a new bulb and see if it blows again.
99zx2 is offline
Old 11-26-2011, 01:43 PM
Take the bulb from the other side and swap it in. If it blows again, it's not a bulb issue.
ChrisMan287 is offline
Old 11-26-2011, 02:55 PM
GarageToys's Avatar
Just to verify-- you know not to touch the glass right? I always wipe mine down with alcohol before installing-- just in case.
GarageToys is offline
Old 11-26-2011, 04:20 PM
ncmaxvq's Avatar
I swapped in the other bulb and it blew also. Found the issue in the process though...the pass side fog is missing that rubber boot thing and i believe it was touching the bulb and grounding out . anyway, i got new bulbs and wrapped the pass side with electrical tape and no issues so far....
ncmaxvq is offline
Old 11-26-2011, 04:25 PM
ncmaxvq's Avatar
Yeah i learned that lesson back in my fast and furious days...yeah thats right i had a SOHC Vtec civic hatch with a fart can (i thought i was the s*hit) and those blue bulbs...went through many sets wondering why the hell they kept blowing..haha
ncmaxvq is offline
Old 11-26-2011, 09:12 PM
chamyang18's Avatar
I changed the fog light relay for the factory fogs to work. Still doesn't work even swapping bulbs from one to another. In need of assistants.
chamyang18 is offline
Old 11-26-2011, 09:22 PM
You check the fuses?
Old 11-27-2011, 10:44 AM
heathbresee's Avatar
good job man
heathbresee is offline
Old 12-04-2011, 06:59 AM
chamyang18's Avatar
I'll check it again.
Old 12-05-2011, 01:04 AM
malamgir85's Avatar
try to trace the wire on ur pass side to see if its open and touching metal or anything
malamgir85 is offline
Old 12-05-2011, 06:18 PM
ncmaxvq's Avatar
it was...problem solved!
ncmaxvq is offline
The Frye
09-02-2021 11:03 AM
03-12-2020 12:06 AM
conansriver
11-18-2015 02:46 PM
minsbang
09-11-2015 08:48 PM
Quick Reply: fog lamp bulb issues
