power door locks, locking randomly
Old Nov 26, 2011 | 04:49 PM
max ride 41's Avatar
i know ive seen a couple of threads on this, i tell you what mine does. i open the doors with the remote and when i open the drivers door all the rest of the locks lock again. key could be in ignition or my pocket. the lock behind drivers door started not unlocking fully and even after i manually pull the lock open it relocks itself again. its been doing this randomly for awhile, im thinking actuator, or a short, but where do i start??? thanks
Old Nov 26, 2011 | 06:59 PM
darrick's Avatar
Dallas Nissan Enthusiast
I have this same problem what the heck is going on here?
Old Nov 26, 2011 | 07:24 PM
i think the colder air has something to do with it. but it got up to 65 yesterday and it still did it. i think i slammed the door and maybe loosened up the master switches???
Old Nov 26, 2011 | 07:43 PM
Nopike's Avatar
If I remember correctly when you lock the drivers door lock the car automatically locks the rest of the doors. There is probably something going on with the drivers door lock.
Old Nov 26, 2011 | 08:08 PM
Same problem here. I locked my keys in the car one time because of it. I kinda just deal with it.
Old Nov 26, 2011 | 09:13 PM
my concern is that i go to the mall, or a store, or an unfamiliar spot and the alarm does'nt set because of it. its happened allready.
Old Nov 26, 2011 | 09:22 PM
my concern is that i go to the mall, or a store, or an unfamiliar spot and the alarm does'nt set because of it. its happaned allready.
I'm pretty sure the alarm still sets. If it doesn't, you can still use the key fob to set it.
Old Nov 26, 2011 | 09:41 PM
DennisMik's Avatar
The master power window switch in the driver's door sends signals to the door locks. Strange as it sounds, there is a microprocessor in the driver's door window switch. What could be happening is that the electrical ground in the driver's door may be bad.
This is just a guess, but with the age of our cars, it is a possibility.
Old Nov 26, 2011 | 11:35 PM
asand1's Avatar
^^This. My car does it too. Its a bad switch that thinks your locking the door, and triggers the electric locks. Eventually I'll see if I can unplug that switch.
Old Nov 27, 2011 | 04:52 AM
can it be cleaned or replaced???
Old Nov 27, 2011 | 01:12 PM
asand1's Avatar
Honestly, its just an educated guess. I need to check the FSM and pull my door apart.
As it stands, when I unlock with the key I have to hold the key in the 3:00 position to open the door or it will lock again before the door is opened. Also, while driving the doors will lock and the relays will continue to cycle.
Old Nov 27, 2011 | 01:24 PM
GGENIUS's Avatar
take your door apart and inspect everything to do with the locks and windows. when my window motor found a way to come apart, my doors were doing this bad. once i fixed it, my locks went back to working normally.
Old Nov 28, 2011 | 11:07 AM
cashoit's Avatar
adjust the door lock rod linkage inside the door. The inside lock isnt mating all the way.
My car did this until i had to get the outside key cylinders re-keyed. Once i reinstalled and tightened everything up I had to go back in the door to adjust the rod to get the inside lock to seat completely.
Old Nov 28, 2011 | 05:45 PM
JtzMax's Avatar
Whatchyou say?
Sounds like a bad BCM to me .... for all of you that have this issue. As our 4g's get older, more stuff will start to happen to them. Check out FSM EL-187 (at least in my 98' FSM). Other thing it could be would be the LCU01 (logic control unit) that interfaces with our front door locks. It also interfaces with the windows (all 4) and if you're not having issues there, I'd suspect BCM - much more likely to be the cause of the issue. Try changing it out with one from a scrap yard - maybe cost you $25 - $30 or so ....
On another note - for free .... check your Gnd cable from the battery to the Gnd'ing spot on the front of the block - maybe take if off, clean it with a wire wheel or brush, put it back on and see if the problem continues.
Old Nov 28, 2011 | 05:49 PM
JtzMax's Avatar
Whatchyou say?
Could be it ... but if he hasn't taken anything apart, not likely it somehow self adjusted to cause this issue.
OP: does the lock turn easy or is it really stiff? If it is stiff, Cash might be onto something ...... I'm not always right ...
Old Nov 28, 2011 | 07:04 PM
so, your right some of the times???
Old Nov 28, 2011 | 07:24 PM
Trini Boom's Avatar
I experience this same issue except that all the doors lock back except the passenger front door. Have you guys looked at that door also to see if it locks? If not, I would suspect my problems is in the passenger side door. For you guys, its the drivers side door if all doors are locked. I may check the linkage as cashoit stated.
Old Nov 28, 2011 | 09:09 PM
JtzMax's Avatar
Whatchyou say?
Touche .... lol
Old Nov 30, 2011 | 11:40 AM
cashoit's Avatar
So u guys didnt see the thread where the entire rod had rotted away at its mounting point. To fix it, some kid had to use clamps and tubes to connect it back up.
Old Nov 30, 2011 | 12:00 PM
T_Behr904's Avatar
Sounds like your cars are possessed by demons
Old Nov 30, 2011 | 12:41 PM
I was bored today and disconnected/reconnected my main door switch and all is well so far. Will see over time how it goes.
Old Aug 18, 2012 | 04:39 PM
asand1's Avatar
FIXED
Today I decided to fix my door locks.
I had noticed the passenger door lock was not moving when I hit the unlock button on the drivers door. This in turn was triggering the BCM with a "door locked" signal, and thus locked all the doors again.
I pulled the door panel off, and the door latch assembly out. I greased all the plastic clips for the rod controls and adjusted the lock control rod bell crank up/out. I used white lithium grease on the rod clips, and motor oil on the bell crank pivot bushing. The locks work better than they ever had since buying my car three years ago.
ef9
Sep 29, 2015 11:29 PM
johnaschon
Sep 14, 2015 04:29 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
