big problem
Old Dec 17, 2011 | 12:45 PM
cjones450's Avatar
big problem
Ok well I drove this morning with no issues and now all of a sudden it started running like **** blowing blue smoke and the car runs without the key any idea
Old Dec 17, 2011 | 12:48 PM
GGENIUS's Avatar
you dont have a remote start system by any chance do you...
Old Dec 17, 2011 | 12:50 PM
Goomz's Avatar
your car sounds like its burning oil/ign cyl broken but you did not include enough info.
Old Dec 17, 2011 | 12:57 PM
cjones450's Avatar
It has an aftermarket alarm that the fuse is not in and is disabled the car has had no problems for the last month never burned a drop of oil no issues except one or two of the coils are bad
Old Dec 17, 2011 | 01:51 PM
cjones450's Avatar
I added gas and oil car still has the problem the car is flooded with gas that has had no issues at all tmand then all of the sudden inflow of if all the car back fires throughthe intaket
Old Dec 17, 2011 | 02:45 PM
Trini Boom's Avatar
Sounds like multiple injectors are malfunctioning. Have you ever replaced your fuel filter? You want to replace the defective injectors and replace the filter if you haven't.
cjones450's Avatar
O found that gas is pouring from the muffler
Old Dec 17, 2011 | 02:51 PM
Trini Boom's Avatar
As I stated, injectors are malfunctioning and if you say gas is coming out the muffler, the injectors are stuck open which is letting in any amount of gas in the cylinders. You want to get to that before the cat converter and your O2 sensors get the worst of it.
Old Dec 17, 2011 | 02:53 PM
cjones450's Avatar
i will look into it i found that 2 of the forward spark plugs are black so ill look into injectors
Old Dec 17, 2011 | 03:04 PM
Trini Boom's Avatar
Take all 6 out and you will see that the ones that are wet with fuel are the defective injectors.
Old Dec 19, 2011 | 06:46 AM
cjones450's Avatar
U were right about the Injector one of the lower orings on line of the front injectors came apart I changed the orings and all better and believe it or not it also fixed my extended crank issue and my rough idle
Old Dec 22, 2011 | 08:33 PM
Trini Boom's Avatar
Old Dec 22, 2011 | 10:45 PM
ShocknAwe's Avatar
As I was reading this thread I almost expected to see a picture of a fire at the end. Goodness gracious that could have been bad with gas leaking out of your muffler. Glad you fixed it though. VQ's always keep on trucking. I dont know why the U.S. military doesnt use them......hmmmmm
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
slowlifer
Sep 8, 2015 05:53 AM
