BOSE?????
Old Dec 22, 2011 | 06:24 PM
heathbresee's Avatar
BOSE?????
ok so my Bose works decent but my back speakers are not working i know theres a thread on how to repair it but is is there a way just to rewire them? like to the front speakers or something
Old Dec 22, 2011 | 06:28 PM
ShocknAwe's Avatar
Take them both off and inspect them, probably a broken solder point. If you have a little electrical knowledge then it should be a simple fix.
Old Dec 22, 2011 | 06:37 PM
ive looked them over several times i havnt seen nothing and i have a bit of electical knowledge.
Old Dec 22, 2011 | 06:41 PM
ShocknAwe's Avatar
It might be hard to catch with the naked eye. Loose wires. continuity test? If they dont work at all then it is probably a wiring issue. Do you have another speaker to test if the wiring is good? Go at it with the multimeter and you should find your problem. It is about a 15yr old speaker and even a Bose will go bad.
Old Dec 22, 2011 | 06:43 PM
could it be a wiring issue in the HU?
Old Dec 22, 2011 | 06:44 PM
ShocknAwe's Avatar
It could be a damaged wire anywhere from the HU to the speaker itself. I would start by testing the speakers though and ensuring they are getting power and grounded properly
Old Dec 22, 2011 | 07:09 PM
well i have a multi meter would u mind explaining how i would go about testing them
Old Dec 22, 2011 | 08:11 PM
ShocknAwe's Avatar
just do a google search of testing speakers. there are tons of youtube videos as well. It will be easier to follow than me walking you through it
Old Dec 22, 2011 | 10:06 PM
95max87's Avatar
I would try testing the speakers first, maybe on a different type of radio (one that doesnt have built in speakers, a surround type speaker setup if you have one). If the speakers are bad then replace the speakers, if they are good then you should try with the multimeter. If the wires are good then you can google "nissan maxima bose wiring diagram" and pull one up. Look at the color scheme for the speakers and wires and you should be able to wire the backs with the front (sure it'll take some splicing and reconnecting, but what the heck..) post with results.
Old Dec 23, 2011 | 05:00 AM
DennisMik's Avatar
I hate to be a pessimist, but I think you have a head unit problem. Each of the speakers is has its own wiring and stuff. The only common point would be the amplifier portion of the head unit.
Old Dec 23, 2011 | 06:29 AM
well thanks everyone for the ideas given me alot of help. its 22 degrees out right now so there wont be any updates for about an hour or so. im gna taje one of the speakers out and test it first..... and if the head unit is the problem is there a way to fix it?
Old Dec 23, 2011 | 09:31 AM
Not a good idea. All speakers will play at the same level. You'll have no front/rear fade control.
In the quote above, you state you have quit a bit of electrical knowledge...surely you can test the speakers with a multimeter
Also, read this....most of your thread titles are lame...
http://forums.maxima.org/4th-generat...e-contest.html
Old Dec 23, 2011 | 09:54 AM
ShocknAwe's Avatar
your gonna have to provide more info than this. Insure both speakers are getting 12V. the connections coming out of the HU are good. Lastly, test the speakers and you will probably find your problem
Old Dec 23, 2011 | 11:35 AM
ok guys fixing to head out to the car and see what i can do.. i just hope it aint a resistor or something im about broke and even though there cheap i still cant get one lol...... wish me luck
Old Dec 23, 2011 | 11:52 AM
Nopike's Avatar
Exactly. The only other thing common is some of the 12VDC wiring.
Unless you were playing the HU at full blast when the trouble occured it seems unlikely both speakers would fail at exactly the same time so the actual speakers are probably OK. It sounds like whatever failed is common to both speakers so it's not individual speaker wiring either.
Disconnect the four pin connector at each speaker
With the HU on, use your meter to make sure you have 12VDC between each speakers red wire and black wire.
Old Dec 23, 2011 | 11:54 AM
also this is a crazy question but i dont have a soldering iron but alot of jb weld would it work in very small ammounts
Old Dec 23, 2011 | 12:07 PM
Nopike's Avatar
I don't think you need to worry about soldering at this point.
When did the problem start? Is there something that was being done that may have caused the problem. Were you or someone else working on the stereo?
Old Dec 23, 2011 | 12:25 PM
i bought the car like that over a year ago but now i really want to hear how it sounds with all speakers going
Old Dec 23, 2011 | 01:23 PM
ok im getting 12 volts to the speakers now what?
Old Dec 24, 2011 | 02:28 AM
Maxmillion's Avatar
The Bose sounds great in my 95 GLE but the radio's digital display only works periodically. Anyone else experience this? Thanks
Old Dec 24, 2011 | 04:27 AM
Thaboywonder6588's Avatar
With Our Years (95-96) There Were A Ton Of Issues For Them... To The Point Where They Don't Repair Them Anymore... Carstereohelp.com specializes in Bose repairs but they only offer upgrades for us... $250 For Head Unit & Wiring Harness
Old Dec 24, 2011 | 10:45 AM
larso1's Avatar
Replace with a new dbl DIN Pioneer AVH-P3300BT touch screen head unit with Blue Tooth, ipod and USB ports, and DVD player. $350 new in box most places. The BOSE HU in my '97 SE started acting up with the CD section making cycling sounds for no apparent reason and the volume control would go loud, then soft, didn't work proportionally with the **** turn. Replacing with the Pioneer
Old Dec 24, 2011 | 02:00 PM
Maxmillion's Avatar
Thanks guys, my speakers seem okay, would you recommend simply hooking up the existing speakers to that Pioneer hu? I was just looking at Boxing Day flyers, there's some sweet deals out there, even ones with navi. Cheers!
Old Dec 24, 2011 | 02:03 PM
Maxmillion's Avatar
Just googled that Pioneer AVH-P3300BT, nice! Anyone got a photo of one installed in a 4th gen? Does it fit in the hole?
Old Dec 24, 2011 | 03:23 PM
larso1's Avatar
Fits our car w/ Bose for sure. http://www.crutchfield.com/p_130P330....html?tp=20217
But Crutchfield is an extra $100 which includes special install directions for our car, etc.
You'll need this $40 adapter from Crutchfield to use the existing Bose speakers with amp
http://www.crutchfield.com/p_142C4NN...r.html?tp=3486
Old Dec 24, 2011 | 11:54 PM
2brosgixxer's Avatar
You really shouldnt be asking your questions on someone elses thread. Go to the 4th generation section and look there for a thread/sticky right at the top called (or just click the underlined part here) NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting! Thats where you post YOUR questions until you can start your own threads. You'll probably get more answers there too.
Old Dec 25, 2011 | 05:35 AM
I'm Just Mainly Concerned About Blowing Speakers Out Since I Tend To Play My Music At Ignorant Levels
Old Dec 27, 2011 | 04:57 AM
Are You Keeping The Bose Speakers In? I Was Looking Into This Stereo And I Admit That It Looks Pretty Good... Just Wondering If I May As Well Remove The Speakers While I'm At It
Old Dec 27, 2011 | 07:42 AM
larso1's Avatar
My plan is to keep the Bose speakers with individual amps and incorporate the Scosche integration adapter recommended for the Nissan Bose system:
I have the Pioneer HU and the adapter (XMas present), just need better weather to start the install.
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
