Clutch Issue / Manual
Old Jan 3, 2012 | 03:17 PM
rhonster's Avatar
97 5spd with 206km, recently noticed an rpm surge when hitting the pedal hard, example flooring the gas at 65mhp will cause a bit of an over-rev until the clutch catches up and power train falls in line. Also similar in lower gears when accelerating above normal. Fluid level is ok albeit with a very slow leak that is hardly noticable and only requires a top-up a couple times a year. (Using Dot 3 Super Heavy Duty Brake fluid to top up.) Very cold here, is this a temperature deal, possibly? What needs to be replaced or what is the cure?
Old Jan 3, 2012 | 05:48 PM
luke95gxe's Avatar
your clutch is slipping time to have it replaced while u have it replaced get the flywheel resurfaced to remove any glaze clutch kit 170 or so from parts stores flywheel resurface 40-60 bucks good luck
Old Jan 3, 2012 | 06:47 PM
fat_kid's Avatar
2nd that
Old Jan 3, 2012 | 07:03 PM
rhonster's Avatar
Any problem with eBay aftermarket, oem or equiv spec like these?
Item number: 280792278638 @ $40 plus ship
or: 400175908815 @ $55 plus ship
or: 160659363489 @ $69 plus ship
Old Jan 3, 2012 | 07:39 PM
asand1's Avatar
Do a stock 5th gen clutch. Also, replace your line with a one piece braided stainless steel one.
Old Jan 3, 2012 | 07:59 PM
rhonster's Avatar
By "stock", I presume you mean OEM from the dealer. To late to call tonite, but I have got to think the price difference will be astronomical. The items I listed are compatible to 4th and 5th generation. Is OEM that big of a deal?
Old Jan 3, 2012 | 08:22 PM
back2basics's Avatar
Do a search for the 5th gen clutch replacement and you'll find alot of info on it including the stock numbers for all the parts you will need to do the job.
If you punch each of those numbers into a search separately you'll be surprised how low the prices can be.
You are lucky you got as many miles out of that one as you did, mine is going and it's only at 150k right now, since I'm the third owner I have no idea how it was driven before I got it.
The stock 5th gen is a great way to get better clamping force along with really good reliablity.
Since you are already going in be sure to replace your throwout bearing as well and while you are already in their I would recommend replacing you rear main seal while the tranny is already out, it's well worth it at that mileage to get it out of the way so it doesn't fail later after you put the trans. back in.
Old Jun 27, 2013 | 04:14 PM
captchaos's Avatar
OK I have the same issue as the thead starter "Rhonster." I have a 98 Maxima SE 5sp... bought it a year ago and put 9,000 miles on it. It has 170k now.
Just recently (couple of weeks ago) when I hit the gas the RPM's go up but the car is not responding well. It's slipping! Eventually it catches up but slowly. If I feather the clutch in 1st and 2nd it's not as bad but if I have to accelerate from a dead stop I'm not going anywhere fast. The RPM's will go up but the car does not accelerate fast at all.
It appears I need a new CLUTCH KIT. I am not going to keep the car for long so I was going to go with a RhinoPac/World Car Clutch Kit on Rock Auto for $108. I don't need anything fancy. I just want her to drive right. There are more expensive Clutch Kits made by Exedy, ACDelco, Valeo, and Beck/Arnley. The price range is from $108 - $160.
Should I also replace the Pressure Plate or just get it resurfaced?
Also should I get a new master and slave cylinder? They are $25 & $20 respectively. The guy doing the work said I just need a clutch kit.
Also I cannot find the Throwout Bearing or the Rear Main Seal on Rock Auto. Are they called something else? I am a novice so please explain like I'm a dummy!
Any advice is greatly appreciated!!!
Old Jun 27, 2013 | 04:16 PM
captchaos's Avatar
I forgot... How long should it take to replace the Clutch Kit? Just wondering...
Thanks guys!
Old Jun 27, 2013 | 04:29 PM
rhonster's Avatar
Thanks guys!
there is a lot of stuff to be removed to get to the clutch, so count on some time. Other than that, it's not that big a job. I wouldn't mess with the master/slave setup and you will know more about resurfacing once it is opened up. If you want to wait and see if you need the extra part, your call. Just don't put on a racing clutch, any stock one on eBay or wherever should be fine.
Old Jun 27, 2013 | 04:36 PM
rhonster's Avatar
$80 all parts
http://www.ebay.com/itm/Perfection-Clutch-MU47760-1-Clutch-Kit-/281094364565?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AMaxima%7CYear%3A1997&hash=item4172879d95&vxp=mtr
Old Jun 28, 2013 | 09:12 AM
captchaos's Avatar
Thanks man. I'm going to purchase this right now! Thanks for the info on the master & slave too.
Old Jul 3, 2013 | 03:40 AM
Boothers96's Avatar
Just did a clutch job on the max last week....first time for me replacing a clutch on any vehicle too. Anyway it took about 3 hrs to get the trans/clutch/flywheel off (i only removed the pass side axle not the drivers) i paid $130 for the perfection clutch kit (lifetime warranty) from Advance Auto, $35 for a f/w resurface and about 3 hrs to reinstall everything without a trans jack, by myself, in a dirt driveway Anyway its been about 200 miles and ive done probably 2 3/4 throttle pulls and im very happy with how the pedal and clutch feel.
My two bits worth.
Also make yourself a diagram for the bolts that hold the trans to the engine as some are different lengths, and take a little sandpapter to where the starter mates to the trans so you get a solid stater ground.
Old Jul 3, 2013 | 05:32 AM
Max_Gator's Avatar
Just my two cents.
Contrary to what someone above said, doing the clutch yourself is not an easy job unless you have some experience.
I'm pretty experienced, have all the necessary tools and still find it to be a pain in the ***. (I've done it several times now). The worst part by far, for me, is properly lining up the transmission to remate it with the motor.
I use an atv jack and shims to get it lined up correctly, then move the trans and engine together, then use a screwdriver to turn the flywheel so it mates properly.
Anyway, it takes a lot of time. If you are keeping the car for any length of time, I would invest in a quality clutch kit so you don't have to do it again in a year. Paying $100 for a clutch kit scares the hell out of me. Exedy makes a nice Stage 1 clutch kit for about 350. For me, it is not about having a warranty, it is about not having to do the labor again.
If you are going oem, there are two kits. Avoid the cheaper one, it is notoriously inferior.
Make sure that you clean and scuff the mating surfaces on the trans. I used a dremel with the BRASS brush on low speed. Don't use the wire brush because it will damage the surface. I then clean with acetol.
If you don't do this, your car may not restart.
Also, I would suggest that you check the axle seals. This is the time to replace those.
Old Jul 3, 2013 | 05:39 AM
Max_Gator's Avatar
Our rear main seals rarely fail. The only time they do fail is when oil has been overfilled. I wouldn't touch it. I have a 4th with 300k and a 5th with 220k and neither have ever had an issue.
What many mistake for a rms leak is a leak from the half moon seals on the upper oil pan.
Doing that repair is another 3-4 hours worth of work. But you have to drop the trans to do it, so if you have an oil leak that looks like it is coming from where trans and engine meet, you should consider the repair.
Old Jul 3, 2013 | 05:47 AM
Max_Gator's Avatar
Thanks guys!
It depends on your experience level.
Your posts makes me think that you don't have much experience working on cars. Maybe I'm wrong.
If that's the case, I would set aside the weekend. Take your time, make sure you takes notes of what you take apart and how you did it. Label the parts you take off. Make notes of which bolts go where on the trans.
There will be things that will take you a lot of time to figure out.
It takes me probably about 4-5 hours to turn it around. That's with all the right tools and impacts. And with properly cleaning and prepping the surfaces, cleaning the inside of the trans, etc. And with the trans going back on without much of an issue.
Old Jul 3, 2013 | 09:24 AM
Boothers96's Avatar
This is absolutely NO JOKE! It was the bigges PITA of the whole job. It took me the better part of an hour just to do this. What i did was lower the car as close to the ground as i could and i tried to use a jack to line it up but it just wasnt working. So i leaned over the drivers side fender, bear hugged it and stabbed it on a one in a million shot lol...Im sure having better tools wouldve made it easier but thats how it worked for me.
Old Jul 4, 2013 | 04:08 AM
Max_Gator's Avatar
How in the hell you made that work I will never know!
Old Jul 4, 2013 | 04:31 AM
maxgtr2000's Avatar
KH3 by popular demand
I used a rolling jack and a block of wood to line it up, it took a few tries and some maneuvering. Definitely better with some help since it weights about 150 lbs.
Old Jul 6, 2013 | 04:18 AM
Max_Gator's Avatar
Lol... got ya. I thought it was with you just pulling it up.
And I would say it is 85. Feels about like a 85 lb dumbbell.
MAXSE5SPD
Sep 17, 2022 04:00 AM
pktaske
May 6, 2016 07:49 AM
BkGreen97
Apr 2, 2016 05:47 AM
pjgreek
Sep 9, 2015 09:30 PM
pktaske
Sep 4, 2015 08:40 AM
