Koyorad
This doesn't pertain to a Maxima, but I put an OEM spec radiator in my '94 Accord Coupe and it was a perfect fitment. I bought it for about 50-60 on eBay and it always performed well. Never overheated and ran cooler too.
it depends on what your intended use is as well. If you are just looking for an easy install radiator that fits with no B.S. and cools properly than the Koyo stock replacement sold in the group buy is a great set up.
If you are racing your car and need to have better more hardcore cooling than you may want to look at some of the other options that may not be so easy to install without a little modification.
I installed the Koyo in my car and it works great, fit right up with no issues and I had it done in only and hour or so with removing the old coolant, installing all new hoses (totally recommend this if you are already in their) re-installing the fans and double checking for leaks after the refill.
Good Luck.
Good Luck.
Good Luck.
Good Luck.
I appreciate the help so far everyone, so thank you
I'm running Koyo radiators in both my cars. They work just fine in our 110 degree summers. here's the link to the group deals thread:
http://forums.maxima.org/group-deals...t-pricing.html
At least do the silicone hoses then. I always put in higher grade parts than I need because I know I will continue to modify. I dont want to have to replace a part thats still essentially new just because it cant keep up with the POWAH....That I dont quite have yet :-(
Since you are draining everything and replacing hoses, go ahead and replace the thermostat also. Inexpensive, and easy access with all that other stuff out (thought it will help to also upbolt the horn on that side and move it out of the way).
Has anyone bought any of the radiators from this company KoyoRad, and if someone would be so kind enough to state any thing about Koyorad's radiators.
Any info along the lines of;
-price
-fitment
-performance
-price
-fitment
-performance
mclasser
04-08-2015 11:48 AM
F35-JSF
06-20-2012 09:46 PM
