Which nub do I sand off for clearance light mod?
Old Jan 1, 2002 | 06:13 PM
ptatohed's Avatar
Licensed to Spell
I want to do the little trick I have read about you guys doing to keep the clearance lights bright all the time (when the headlights are on) and not just when you signal. Do I sand the lower or upper nub? And then just put the lightbulb in 180^, right? Thanks guys.
Old Jan 1, 2002 | 06:22 PM
benny's Avatar
The mod you are talking about is for 97-99 clearance lights
you use a 1156 bulb instead of the 1157 bulb. File 1 of the
nub off and put it in and it will be brighter. Good luck.
NYCe MaXiMa's Avatar
Re: Which nub do I sand off for clearance light mod?
I believe it is the upper one... that way you can turn the bulb the other way, with the lower nub going into the socket of the upper one...
again, i have done this and it works great, but i really am not 100% positive, about 90% sure its the upper one.
Old Jan 1, 2002 | 06:26 PM
JdawgX's Avatar
I didn't have to sand off a nub. I just re-soldered the wire to the other contact. Then put the bulb and the assembaly back together and it worked great. Hope that this helps.
Old Jan 1, 2002 | 06:38 PM
Mad Dhan's Avatar
So i can not do this sanding thing for my 96? I need to solder? I was just about to go do it. Now i have to look for all my elec crap.
Old Jan 1, 2002 | 06:44 PM
JdawgX's Avatar
All I did was to take the assebaly apart, move the wire from the contact that it is currently on to the other one, and put it back together. Then stuck the stock bulb back in and turned it on. But mine is a 97, so I'm not sure if you can do the same thing. Sorry bout that.
Old Jan 1, 2002 | 06:47 PM
ptatohed's Avatar
Licensed to Spell
:o)
Right, why won't this work for a '95/'96 benny?
NYC, the upper one makes sense, thanks. Can anyone else confirm that real quick before I go and do it? (I have a '96)
Thanks guys.
Old Jan 1, 2002 | 06:59 PM
guitaraus's Avatar
Re: :o)
Thanks guys.
Confirming...my '95 has 1156 bulbs with a shaved nub in backwards...works beautifully. Just so you know. Take an 1156, the bulb with the one bump on the bottom, look at the nubs on the side, shave off the one closest to the glass, put it in backwards of how it would go regularly. Voila!
Peace
Old Jan 1, 2002 | 07:58 PM
ptatohed's Avatar
Licensed to Spell
Re: Re: :o)
Peace
Thanks guitar., I really appreciate that. When you say 1156, you mean the stock bulb size it comes with, correct? And I wasn't following you with the one closest to the glass. Do you shave the upper or lower nub? Thanks again.
Old Jan 1, 2002 | 08:17 PM
Mad Dhan's Avatar
damit, this is harder than i thought. Not so much the auctual shaving of the nub but getting the bulb out!! I got the passenger side to work fine with the stock bulb, i just sanded away the uper nub with reg sand paper. Now i cant even get to the divers side off, wtf! Is there any easy way to get to the bulb, my fingers do not fit in those tiny places and i cant get enough leverage to turn the socket and get the bulb out........there has to be an easier way???
Old Jan 1, 2002 | 08:38 PM
ptatohed's Avatar
Licensed to Spell
:o)
Mad, so are you saying it is definately the upper nub that needs to be sanded?
Why don't you just remove the whole clearance light? Just one phillips screw, a good wiggle and a tough ball-in-socket and you're there.
Old Jan 1, 2002 | 08:42 PM
Mad Dhan's Avatar
Re: :o)
I dont know why i added mad to my name you know that, im usually just dhan. anyway yeah its definatly the uper side
Old Jan 2, 2002 | 09:02 PM
guitaraus's Avatar
Re: Re: Re: :o)
1156...stock bulb size, although mine are hyperwhites, and it's the upper nub, the higher up nub, the nub closest to the glass, the nub furthest from the connection, then upper nub.
Peace
Old Jan 3, 2002 | 01:15 AM
ptatohed's Avatar
Licensed to Spell
Re: Re: Re: Re: :o)
Peace
I'm sorry, I understand what you mean by closest to the glass now. I was looking at my bulbs and I had 1156 stock, not 1157. What's the difference? Hey, since you brought it up, can you tell me how you like the hyperwhites, where to get them, the cost and just how white they are. If I have Piaas headlight bulbs, will the clearance lights match them close? Thanks.
P.s. I didn't sand off the nub at all. I simply bent the wall of the light socket ever so slightly and fit it in. No permanent damage.
Old Jan 3, 2002 | 07:51 AM
guitaraus's Avatar
Re: Re: Re: Re: Re: :o)
Well, I have headlights and fogs from the same company...some guy sold them to me on ebay, I don't know who makes them because there was no English writing on the packaging, it was all Japanese. I don't remember where I got the clearance bulbs. They don't match perfectly, but they don't look bad. I like 'em. I left stock clear bulbs in the sidemarker and turn signal so that I can still have some resemblance to amber for a blinker. Good idea with the socket thing!
Peace
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
