does the A32 cefiro parts on ultraracing.com work on our 4th gens. anyone experienced
Old Jan 19, 2012 | 02:47 PM
  #41
RA030726's Avatar
I'm nutty for Nissans
Originally Posted by MaxiNone
doesnt the MEVI sit a bit higher than our stock intake manifolds? if the MEVI is a bit higher than these bars should fit over our stock manifolds with no problem, right?...
Old Jan 19, 2012 | 07:53 PM
  #42
xtremepb0's Avatar
Good that you dont take the interwebz super serious. Feel free to ask question, I (and most members) will say that searching is your friend.
We get a lot of noobs who come in here and ask questions about stuff that there are hundreds of threads about....coupled with this being like the 4th FSTB thread this week I guess I just lost my cool. You will find that I can and am very helpful IF I can answer your question.
THIS... It gets annoying when there are 5 threads in the past week. I understand people are new but the search feature isn't hard to find at all. Also tigersharkdude is one of the most helpful people I've met on the org. Just gets old having to type the same answer all the time that's all.
Old Jan 20, 2012 | 03:37 AM
  #43
SteveB123's Avatar
the .my at the end means you're connecting to a site in malaysia...good luck with that if anything goes south with your credit card
A dealer in New Jersey, and a dealer in New York.
I'm sure he'll order domesticly.
Old Jan 20, 2012 | 03:38 AM
  #44
SteveB123's Avatar
It's possible to just skip the thread, isn't it?
Old Jan 20, 2012 | 01:24 PM
  #45
MaxiNone's Avatar
Originally Posted by JSutter
thanx for the pics, this actually helps me make my decision. i'll see if i can order the rear strut bar from ebay then get the front. if it doesnt work then i guess i'll be out $140 :/
Old Jan 20, 2012 | 01:45 PM
  #46
plbeaulac's Avatar
hello i have a question y buy a maxima last week, its a maxima 1998 clean 71 miles and y have a question ,when a start my motor (only cold ingine) the motor stop in the same second....i put a litle shut of gas 3 or 4 seconde and its ok the car running ...wath is the probleme ?? IAC ...TPS other senser ...(sorry for my english y speak only french lol)
Old Jan 22, 2012 | 06:18 PM
  #47
lealex's Avatar
I bought the A32 ultra racing strut bar from ebay and it seems well made. Unfortunately, it doesn't clear the thing that holds pipe on the left side. I also tried reversing it but then the brake fluid reservoir gets in the way. Any ideas for getting it to fit?
Old Jan 22, 2012 | 06:37 PM
  #48
Originally Posted by lealex
I bought the A32 ultra racing strut bar from ebay and it seems well made. Any ideas for getting it to fit?
You can sell it to me.
Old Jan 22, 2012 | 06:40 PM
  #49
tigersharkdude's Avatar
and then you can sell it to me
Old Jan 22, 2012 | 07:25 PM
  #50
schmellyfart's Avatar
Bend the bracket out of the way or redrill a new mounting hole in the bracket so that it will sit lower.
Old Jan 22, 2012 | 07:37 PM
  #51
MaxiNone's Avatar
Lealex, is that the only thing keeping the bar front mounting? Do the holes line up on both sides? Also, do u have abs?...
Old Jan 22, 2012 | 09:26 PM
  #52
lealex's Avatar
ChrisMan287: Maybe we can work something out if you end up doing that retrofit for me
MaxiNone: No ABS. All the holes line up fine on both sides, but on the right side (bottom picture) there is metal sticking out that needs to be removed because it prevents the bar from going down all the way. Also, there might be some clearance issues with the other stuff in the middle (second picture).
Old Jan 22, 2012 | 09:28 PM
  #53
If only I didn't need money lol
You can bend that bracket towards the motor. It should allow the bar to bolt down.
Old Jan 22, 2012 | 09:31 PM
  #54
Oh I thought you were talking about the ac line on the passenger side (referred to the right side in most cases, which is why I was confused). That bracket on the driver side strut tower is for the second bleeder for the clutch, you can just cut it off.
Old Jan 22, 2012 | 10:01 PM
  #55
Quickywd01's Avatar
The ac line moves around like jelly once you unbolt that bracket which can be easily bent to clear the bar.
Old Jan 22, 2012 | 10:50 PM
  #56
std aja de's Avatar
Pixell
Hmmm as for the 2nd pic I thought the difference is because we're here using MEVI, but wil check it again on my car.
as for the other, I don't have any idea about them, hope so there are good persons help-ing you
Old Jan 22, 2012 | 11:07 PM
  #57
ShocknAwe's Avatar
My car lost that bracket long ago. As well as most of the brackets for the UIM as well because they simply arent needed. I dont even know if mine came with that bracket lol
Old Jan 23, 2012 | 11:18 AM
  #58
95maxrider's Avatar
Lightly modded
Here are some pics from that build thread:
But what I'm most interested in is this:
It looks like this could fit on a car that already has stage 1 SFCs and LTB. However, it looks like it wouldn't work if you have stage 2/3 SFCs or a stage 2 LTB.
Also, does it bother anyone else that their FSTB only attaches to two of the three strut bolts? I'm all for a solid construction and the third connection point to the firewall, but unsure of the 2/3 strut bolts.
Old Jan 23, 2012 | 03:47 PM
  #59
this is what I was wondering. With it only attaching 2 of the bolts, could it put stress on the "front" bolts in corners?
Old Jan 23, 2012 | 06:03 PM
  #60
aackshun's Avatar
Why do the rear struts only have 2 instead of 3?
Probably the same reason why the strut bar is the same way?
Very interested in this stuff, should see it on my other car very soon, making it fit seems to be no problem and having it in white is a WIN for me
Old Jan 23, 2012 | 06:46 PM
  #61
lealex's Avatar
Thanks for the advice everyone. I will give it another shot.
I'm definitely interested in their other stuff as well.
Old Jan 26, 2012 | 12:58 PM
  #62
MaxiNone's Avatar
can some one clarify these acronyms please? i figured LTB is lower tie bar but whats SFC's?...
Old Jan 26, 2012 | 01:02 PM
  #63
aackshun's Avatar
SFC = Sub Frame Connectors
schmellyfart
Sep 25, 2015 04:47 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kirkhilles
Aug 8, 2015 10:53 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
kenc15
Aug 5, 2015 08:29 AM
