Seatbelt light
Old Jan 1, 2002 | 11:07 PM
jsr0367
Seatbelt light
Want to disable that little annoying Seatbelt light that is always on. Any ideas for my '97 SE?
Old Jan 1, 2002 | 11:11 PM
matty's Avatar
Put your seatbelt on
Old Jan 1, 2002 | 11:14 PM
jsr0367
Nice!
Old Jan 1, 2002 | 11:20 PM
tifosiv122's Avatar
Originally posted by jsr0367
Nice!
I do not think you should do this, but you could cut the belt and just place the clicker part in the opening (like it should be). The car will think you are using the seatbelt and your not...like I said, I don't think you should do this.
Erik
Old Jan 2, 2002 | 07:47 AM
clee130's Avatar
Old Jan 2, 2002 | 07:57 AM
jsr0367
For those of you Wiseasses...I can't due to physical limitations in my neck! Let's just answer the question rather than try to be funny!
Old Jan 2, 2002 | 08:00 AM
Vyrus's Avatar
If you reall can't put it on...
Go to advanced autoparts and buy a seatbelt from them (cheap). Cut off the female part and stick it in the socket. Voila! Cheap, easy no more beeping.
-Cyrus
Old Jan 2, 2002 | 08:34 AM
maximadriver's Avatar
On my CRX, all I did was disconnect the wire harness under the seat that connected the belt "clicker" to the car. I thought it would cause the light to be on all the time, but it had the opposite effect. No more light, at all, at any time. I had a book go under the seat in my Max the other night, and when I got it out, I noticed the same type wire harness as in my CRX. I was going to disconnect it and see but I was tired. Hope this helps...
Old Jan 2, 2002 | 08:37 AM
clee130's Avatar
And if you had stated that in your original post, we might not have been such "wise-asses".
We aren't mind-readers you know.
Old Jan 2, 2002 | 09:01 AM
SuDZ's Avatar
Erik
May not pass safety inspections if you do this though.
SuDZ
Old Jan 2, 2002 | 09:43 AM
matty's Avatar
Jeeeez no need to yell...have some fun
Old Jan 2, 2002 | 01:25 PM
njmaxseltd's Avatar
SuDZ
Correction - WILL NOT PASS INSPECTION LIKE THAT.
Old Jan 2, 2002 | 02:52 PM
Greddy97's Avatar
that wire harness under your seat might not be for the seat belt, i think its for the heated seat or power seat option.
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
