Unorthodox Ultra Lightened Aluminum Flywheels (5 lbs.)
Old Jan 2, 2002 | 11:32 AM
maxedout95's Avatar
Anybody knows if this is a good flywheel cause they say that it is only 5 lbs aluminum and that would make it the lightest flywheel that I ever heard of but it is also expensive I think like $ 650 or something like that so what do you guys think is it worth it and what would the advantages and disadvantages be ?
Old Jan 2, 2002 | 11:35 AM
Jeff92se's Avatar
I'm needing a caw
Way too light. Drivability problems probably will occur. Plus rpms will probably drop like a rock when you let off the gas. Take offs with such a light flywheel will probably be a big pain.
If you get one, don't say I didn't warn you
Old Jan 2, 2002 | 12:23 PM
SuDZ's Avatar
At waht point would you say one was not "too light". As in how many pounds do you think would make it still managable for a daily driver?
SuDZ
Old Jan 2, 2002 | 12:24 PM
Jeff92se's Avatar
I'm needing a caw
Well you don't really have too much choice. It seems like it goes from 10lbs to this 5lb unit. 10lbs would be about the lightest I would go.
SuDZ
Old Jan 2, 2002 | 01:37 PM
SuDZ's Avatar
Do you know if a lightened flywheel makes daily driving more uncomfortable or tougher to drive the car. Just curious because I have been intrested before in getting a lighter one but want to know the ramifications first.
SuDZ
Old Jan 2, 2002 | 03:34 PM
CoOlKidS1979's Avatar
I think the flywheel is more than 5 pounds, I think we have 2 peice flywheels, and I think maybe 1 peice might weight 5 pounds but both peices are together then its probably more like 12 pounds. I think alot.
Old Jan 2, 2002 | 07:00 PM
Confused's Avatar
Permanent Maxima.org Resident
This is conceptually correct. The 5lb is for the new piece of the two piece flywheel. You reuse the other disc with the ring gear. Stillen's weighs about 7.9lb if I remember correctly.
Old Jan 4, 2002 | 11:21 PM
Kevin Wong's Avatar
I'm going to go ahead with the fidanza
Vyrus showed a pretty good deal today at ptuning.com. They are offering the fidanza flywheel for $370.45 shipped with "pnismo" for the coupon code. I think the unit weighs in around 6-9 punds plus the weight of the outer and the bolts on the flywheel should bring the grand total to 12 pounds...just over half of the stock weight.
Old Jan 5, 2002 | 01:01 AM
kit99bar's Avatar
a lightened flywheel is like lighter wheels
the lighter it is the faster you can rev your engine = faster acceleration
if you have problems with the car's rpms dropping too low just up your throttle wire
adn yes your rpms will drop faster too
Old Jan 5, 2002 | 01:20 AM
ericdwong's Avatar
Gotta chime in on this one. The 2ndary ring gear PLUS the bolts that hold it to the flywheel is an entire ONE pound an SIX ounces. Its insignificant.
BkGreen97
Apr 2, 2016 05:47 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
lux97Max
Sep 28, 2015 11:18 PM
mpbclutch33
Sep 21, 2015 01:54 PM
