is it the right motor
Old Feb 1, 2012 | 06:34 PM
greenspeed's Avatar
Wats up! I got another de but I seen it doesn't have 2 sensors on the motor. These have vacuum lines on them. One next to the map sensor and another near the coolant lines. If I use it as is will my car still run? What will I have to do?
Old Feb 2, 2012 | 05:43 AM
Mr LoL's Avatar
im not 100% sure but i believe that is a 3.3 from the old pathfinders that used vacuum but then again i could be wrong
Old Feb 2, 2012 | 09:09 AM
cardana24's Avatar
Blown
If you really have a vq30de then it should work. If you post a picture here that would answer all of your questions. Does the engine that you purchase look like your old one? Have sensors been taken off of it? I don't really understand what you are saying.
Old Feb 2, 2012 | 09:13 AM
Shift_A32B's Avatar
This.
Old Feb 2, 2012 | 09:27 AM
NmexMAX's Avatar
dot dot dot ...
It's probably the boost sensor that came in 96 and wasn't present in 95's.
Check the block /head under the IM, it will read VQ30DE.
Oh yeah:
Old Feb 2, 2012 | 10:02 AM
greenspeed's Avatar
yeah it a vqde but its missing two sensors. it probably is the boost sensor. my car is a 97. dnt kno wat yr the new motor came out of
Old Feb 2, 2012 | 10:15 AM
cardana24's Avatar
Blown
oh okay, I was not understading the original statement Just make the new engine match your old set up. If it's missing a few sensors then swap them over to the new engine.
Old Feb 2, 2012 | 10:26 AM
greenspeed's Avatar
okay wat about the vacuum lines. can i plug them if not needed
Old Feb 2, 2012 | 10:55 AM
cardana24's Avatar
Blown
you should not have any loose vacuum lines. Make the new engine look like your old one. If you are talking about the emissions stuff that was not on the early 4th gen engines, if my memory serves me correct you can just un bolt it from you intake manifold. Again, a picture would probably answer everything, but in short you want to make the new engine look like the old one, that includes sensors and vacuum lines.
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
