tranny problems
Old Feb 23, 2012 | 05:18 PM
boostedmax305's Avatar
tranny problems
recently was gonna change my tranny fluid and discovered that the sensor was cut from the wire that runs up to the harness and my 3rd gear has been grinding alot lately can it be cuz of that why can it be grinding
Old Feb 23, 2012 | 05:25 PM
036mtmax's Avatar
If your 5 speed then your 3rd gear is grinding because you need synchro's, It has absolutely nothing to do with any wire in on or around your car. If your auto ask someone else because i know nothing about them.
Old Feb 23, 2012 | 06:55 PM
vqmaxman's Avatar
Auto or manual, the wire in the tranny pan, I believe it's the solinoid pack harness that's if your auto. There are bunch of wires on the back of tranny near the intakebox and the battrey is on a auto.
Old Feb 23, 2012 | 07:05 PM
asand1's Avatar
tranny problems
I'm sorry, was it something like this?
Old Feb 24, 2012 | 09:45 PM
It's 5spd
Old Feb 25, 2012 | 10:02 AM
asand1's Avatar
It's 5spd
1st Manual trannies dont use "fluid" autos do. Change your gear oil. Our trannies need GL4, don't listen to the tards behind the counter at the parts store. GL4/GL5 oils will not work, they will cause grinding. I recommend STA LUBE #SL24239. You will also need a smaller 1qt bottle. Napa carried it last time I checked.
http://forums.maxima.org/4th-generat...ml#post7913744
http://forums.maxima.org/4th-generat...gl-4-dino.html
Old Feb 25, 2012 | 10:11 AM
clintb3astwood's Avatar
LMFAO!
Old Feb 25, 2012 | 09:49 PM
JtzMax's Avatar
Whatchyou say?
WOW .... LOL
OP .... our 5spd trans are not the best in the world so it's best to be gentle with them (if you're not - that could cause your grind). You might also want to check your clutch to make sure it's fully actuating. Replacing the gear oil may help, depends on how worn the syncrhos are.
Old Feb 25, 2012 | 10:06 PM
ShocknAwe's Avatar
4th gen tranny issues? gotta be mistaken lol
Old Feb 25, 2012 | 10:33 PM
Shift_A32B's Avatar
I don't get it, is this a magic show?
Old Feb 26, 2012 | 01:36 PM
Nealoc187's Avatar
SLOW
no sensors in a manual trans have anything to do with it's operation, how well it shifts, etc... there are no electrical components to the shifting - that's why it's called a "manual" transmission.
the only wires coming from a manual transmission are the gear position sensor (turns on the reverse lights basically) and the speed sensor.
HOKUSMAX
Nov 13, 2017 04:34 AM
Socalstillen
Sep 20, 2015 11:46 PM
iamute
Sep 20, 2015 05:22 PM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
