interior lights dont work. as well as accesories. i already checked possible fuses
Old Feb 26, 2012 | 07:16 AM
nismo maximus's Avatar
my dome and map light still work. and my gauges still work. my climate control lights up but doesnt blow
my gauge lights, radio, door clearance lights, fog light, and cig lighter dont have any power. and like i said, my climate cntrl turns on, but the blower isnt blowing.
i know it has to be some fuse. i checked the 145a fuse located next to battery. when i was unscrewing the screw, my dome light was flickering, so i figured it wasnt that fuse.
any ideas?
Old Feb 26, 2012 | 07:18 AM
tigersharkdude's Avatar
did you check the fuse in the fuse panel under your steering wheel
Old Feb 26, 2012 | 07:33 AM
i checked majority. like accessories and such that would be the cause. but it doesnt make sense that all the lights and acc would not work. unless they are powered off one.
oh, and my windows and electronic locks dont work. my horn and wipers dont work either
Old Feb 26, 2012 | 08:24 AM
Check your car battery
Old Feb 26, 2012 | 08:28 AM
CMax03's Avatar
...and your fusible links and those pathetic Nissan battery terminals.....
Old Feb 26, 2012 | 08:29 AM
Check all of the 7.5 fuses under the dash.
Old Feb 26, 2012 | 09:52 AM
DennisMik's Avatar
There is a fuse under the hood, 65 amps that powers the cigar lighter, the blower motor and more. It also powers the windshield wipers, so if they work the fuse is ok.
It is a big square one, the front most along the fender. The cover is labeled "FL65A ACC".
Old Feb 26, 2012 | 02:49 PM
well, it turned out to be the 140a fuse. but when we put a new one in, it automatically blew. so im think short somewhere. just gotta find it... gonna be fun. maybe ill just pick up new sub harness and fuse box and try that.
Old Feb 26, 2012 | 02:51 PM
i got a new battery today too, so i know its not that.
but ill check the other fuses too and relays.
Old Feb 26, 2012 | 03:03 PM
DennisMik's Avatar
It takes a real nasty short to blow a 140 amp fuse. The alternator is on that fuse. If the alternator has a shorted diode, that would do it.
Old Feb 26, 2012 | 03:05 PM
New battery means nothing...I've bought 4 batteries in 7 years (for various cars) 2 of them were bad when I bought them
Old Feb 26, 2012 | 05:42 PM
ok. ill check alternator.
maybe its time for a new one too. also, ill check volts while car is running.
Old Feb 26, 2012 | 05:56 PM
Amerikaner83's Avatar
alternators on our cars tend to kick the bucket... if you're on your original one, take it out of the car and take it to an AutoZone or something for testing.
Old Feb 27, 2012 | 07:57 AM
SHIFT_maxboost's Avatar
I went to sell my alternator, original from 97 se, took it to autozone and he ran it 10 times and it ran quiet and performed like brand new.
Old Feb 27, 2012 | 09:51 PM
im thinking bad coilpack. i did some research and found this- http://forums.maxima.org/4th-generat...trol-fuse.html
post 6 to be specific.
maybe related to misfire code as well.
i also know that one of my wires to my injectors has been exposed slightly and somewhat corroded. ill check that out too.
Old Feb 27, 2012 | 10:52 PM
beegeezy's Avatar
Step 1: Use one of these to make a temporary fuse for the 140a circuit: http://www.sonicelectronix.com/item_...ATCFH12-5.html I'm sure you can get one and a handful of 40a ATC fuses from your local stereo shop for a few bucks.
Step 2: Look at the wiring diagram in the FSM, it should tell you all the fuses on that circuit. Unplug all of them.
Step 3: Turn on the car and add one fuse at a time until one shorts. Use the wiring diagram to figure out what items on that circuit.
Step 4: Repair or replace the faulty component.
Done.
Edit: Actually, I just looked at the wiring diagram. The only non fused item on the 140a main circuit is the alternator. (I'm assuming that is what "charge" means on the diagram.) If that is the case then unless you have a shorted wire, which I doubt, then you have a bad alternator...as Dennis suggested. You could disconnect the charging wire from the alternator to easily test that theory. With it disconnected the rest of the components should work fine. If so, time to go alternator shopping.
Old Feb 27, 2012 | 11:12 PM
vqmaxman's Avatar
If you put a new fuse in and it blows out you got a short. Check all of the fuses from the dashboard to the engine bay. Tracing the wire down will take sometime.
Old Feb 28, 2012 | 10:17 PM
well, im not getting any charge whatsoever. i took alternator to oreillys and it tested good.
maybe im not getting a charge because i dont have the 140a fuse in? but i also didnt know if im supposed to have a plastic or non-metallic piece between the terminal and the alternator. so i made one because maybe it was shorting out there. but still no charge. keep in mind i still havent put a fuse in the main spot. so as of now, the car sits dead
Old Feb 29, 2012 | 10:39 AM
DennisMik's Avatar
If you don't have the 140 amp fuse installed, you don't have a connection between the alternator and the battery. The post on the alternator cannot touch the case so an insulator is needed.
And without that fuse, there are a lot of other things that won't work - windows, seats, a/c and the blower motor, cigarette lighter, horns and more.
Old Feb 29, 2012 | 04:42 PM
beegeezy's Avatar
But those things will work off the battery (with the fuse installed) if he leaves the alternator disconnected. Try that first...
Old Mar 1, 2012 | 11:31 AM
got a 120a fuse put in. its all oreillys had right now til i can order one. it runs. but running shows 13.5 volts. so somewhere something is a little messed up.
and i put my ground kit back on which helped
Old Mar 2, 2012 | 02:43 PM
DennisMik's Avatar
Nissan says 13.8 is the minimum, should be more like 14.2. Many people say that they get 13.5 volts when running with a rebuilt alternator. It seems to work out for them.
Old Mar 2, 2012 | 10:22 PM
well anyways man, i appreciate it. you help me yet again!
tsi6001
Oct 3, 2022 10:23 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
Viralkill
Aug 16, 2015 05:09 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
