problem with power steering pump belt install
Old Mar 26, 2012 | 07:32 AM
adeste's Avatar
When I tried to remove the PS pump belt it got snagged on a bracket that is between the oil pan and crankshaft pulley. This bracket also has a wire running into it. When I looked at the CS pulley I saw that it was contacting this bracket, which from comparing to other pictures I saw that this was not normal. I would upload a pic that shows this, but this post will not allow me to add attachments for some reason.
My question is how do I get the CS pulley off this bracket so that I can remove the PS pump belt?
Old Mar 26, 2012 | 07:56 AM
Phromethius's Avatar
you have to upload the picture to Photobucket or something like that and use the embed link to post it in a thread or forum. Only mods and paying supporters can have attachments.
Old Mar 26, 2012 | 08:00 AM
njmaxseltd's Avatar
The bracket your refering to is the CPS (REF) sensor. The pully should not be touching that. If the pully is touching it, either the bracket/sensor is now broken or bent or your pully outter section where the belt runs has seperated from the isolator.
A picture might help us. A shop manual will help you.
Old Mar 26, 2012 | 08:33 AM
adeste's Avatar
Here is a photo of what I was trying to describe
[IMG][/IMG]
Old Mar 26, 2012 | 10:27 AM
adeste's Avatar
So I looked at the pulley again after posting the picture of it and it does look like it has been separated from the isolater. I also tried to wiggle it to see if it was loose, but it did not move. It makes sense because my car sat outside for a couple of months without being used so the rubber inside the pulley probably rotted. So I am guessing that I need to go ahead and just replace the pulley? Any recommendations?
Old Mar 26, 2012 | 04:41 PM
beegeezy's Avatar
Find a good condition used pulley or buy the Dorman brand part from Amazon. A new pulley from the dealer is over $200. http://www.amazon.com/Dorman-594-188...2805366&sr=1-1 Autozone sells this, and it is normally in stock...but it'll run you another 60 bucks from them.
Old Mar 31, 2012 | 10:37 AM
Trini Boom's Avatar
You're a very lucky guy. Get a used one as the dealer charges $306 for it.
vingodine
45
May 21, 2016 12:46 PM
02PearlSE
Oct 7, 2015 02:12 AM
homewrecker
Aug 24, 2015 08:56 PM
Mrbizness1
Aug 18, 2015 08:43 PM
scarletsosa
Aug 17, 2015 09:09 PM
