Axle boot leaking grease
Old Apr 5, 2012 | 07:34 PM
odawg23's Avatar
so i took my wheel off and noticed black grease everywhere behind the wheel. I was convinced there was a tear in the boot. Any of you know the exact replacement for the boot? i looked online and i keep seeing cv boots..is that the same thing? i dont wanna wait until my whole axle goes bad so i want to replace this asap
Old Apr 5, 2012 | 07:44 PM
You might as well replace the entire axle. Since the boot was torn, dirt/debris and water has probably already gotten in there so in due time, the axle will go.
Old Apr 5, 2012 | 07:48 PM
odawg23's Avatar
its not a really bad leak..would replacing the entire axle be worth it even if its a small leak or would just changing the boot be more convenient?
Old Apr 5, 2012 | 07:58 PM
Changing the boot alone isn't convenient at all. It probably takes more work to just change the boot and it's a hell of a lot messier.
Old Apr 5, 2012 | 08:32 PM
schmellyfart's Avatar
It is a lot more work to just change the boot since you have to pull the axle, separate the cv joint, clean the cv joint, repack it with grease, reassembe the joint and then reinstall. I changed two cv boots since the they were only $5 or so. But when the other two boots split I said F*** it and bought axles with a lifetime warranty.
Old Apr 5, 2012 | 08:48 PM
chrome91's Avatar
you can only replace the boot itself if it pretty much literally JUST tore open, otherwise the boot and grease get infected with debris
on most imports anyways you have to replace the axle and its easier
Old Apr 6, 2012 | 06:02 AM
Snypa's Avatar
replace axle and be done.
Old Apr 6, 2012 | 07:41 AM
asand1's Avatar
If it is not knocking yet, and you have more time than money, get a boot kit for less than $15 and get dirty.
Old Apr 6, 2012 | 08:15 AM
tbaGd_jEw's Avatar
I tore a boot, but figured since its only an extra $50.00...I might as well replace the whole thing.
Old Apr 6, 2012 | 10:37 AM
chrome91's Avatar
doesnt matter if its not knocking or ticking, if its been driven with the boot open its no good
Old Apr 6, 2012 | 11:48 AM
asand1's Avatar
Have to disagree with you. I replaced the boot on my driverside almost three years ago. It was still quiet, and grease still in it. Still quiet today with no issues. Clean it out with brake cleaner and regrease when reassembling.
There is a lot of misinformation on this subjuct, mostly coming from people who have not done it (correctly) themselves.
Old Apr 6, 2012 | 12:17 PM
QFT
Old Apr 7, 2012 | 12:27 PM
Trini Boom's Avatar
Seeing that you have experience doing it, I plan to do over my Driver side OEM axle because it is humming and the boot is dry rotting. I bought the kit from the dealer and wanted to know what tool did you get to tighten the bands once complete or did you use a zip tie?
Old Apr 7, 2012 | 12:57 PM
felorojas14's Avatar
Having same problem here. My tear or leak is fresh though. Prob going to replace the axle. Got a quote today for parts/labor $130
Old Apr 7, 2012 | 02:44 PM
asand1's Avatar
I don't recall what bands I used this time. In the past I have used dull wire cutters too crimp the steel hands.
Also have used this tool while working in shops.
http://reviews.matcotools.com/7535-e...ws/reviews.htm
Old Apr 8, 2012 | 05:27 AM
Trini Boom's Avatar
Ok which means I can get this tool at any auto parts store and they are universal. Thanks a lot.
litch
123
Jan 4, 2024 07:01 PM
The Wizard
24
Oct 1, 2015 08:47 PM
followthadollar
Sep 17, 2015 06:31 PM
Bonka
Sep 14, 2015 11:18 PM
