Always Illuminated Manual Climate Control - Is it Possible and How?
Ok, so obviously there is a how to on how to make the clock always bright, but is there any way to make the climate control always bright? I put some LED's in my gauge cluster but if I use the dimmer to dim them, I cant see the climate control buttons. Yes, I am well aware that i can LED the climate control, but I dont want to. So, anyone know if it's possible to snip a wire to make the climate control NOT dim with the dimmer?
See post #20 for the how to with pics.
Regarding the clock, the illumination wire doesn't power anything, it just acts as a signal for the dimming feature of the display. The same circuit/wire powers the bulbs inside the car, so if you snip it at the climate control, you're killing power to the bulbs. So the answer is no, but you could create an isolated illumination circuit. Best to use a relay powered by the stock illumination circuit to toggle a constant source. That way the headlight switch will still control the climate control illumination.
Or you could simply put the incandescents back into the cluster, or install LED's in the climate control.
For the relay wiring, you would want a normally open relay and wire it up as follows.
GND - coil a
Illumination wire - coil b
Constant source - terminal A
CC Illumination input - terminal b
It will be easier and more efficient to perform the diode/resistor mod. Ideally you would want a very small relay if you chose to go the relay route.
Yikes!! You lost me LOL. I am good at a lot of things, but electrical has never been my strong place. Guess its just gonna be easier to get some LED's for the CC and swap them out. I was not aware at the time of this thread that superbrightleds.com had plug and play led's for the CC for $2.49 a piece. I'll probably just go that route and save the headache. I was just hoping to do this CC mod would be as simple as the "always illuminated clock" mod but I guess it's not....atleast not for me. Thanks for your input.
It can be done and it really isn't that complex. Not all of the lights in the interior dim. Some are not wired through the dimmer switch. It would be a matter of cutting and splicing wires to remove the climate control lamps from the dimmer circuit and put them on the constant circuit. Find the 2 wires and cut and splice.
The only light I've found that might remotely work would be the.glovebox or ashtray. but, the glovebox light does not come one unless the glovebox is open and the ashtray light I don't know cause the bulb has been blown since I've owned it. So id have to override that feature somehow as well. But yes, I was thinking this exact thing, just splice into something else. Like I said, electrical is not my strong field so hoping someone can lay it out for me... like which wires to cut and splice. I looked at the fsm last.light but I was.like reading a foreign language to me lol
Wait, locate the wire from the dimmer switch to the cc and ground that wire at the cc? Can it really be that simple? I'll look tomorrow. If anyone knows what color that wire is behind the cc, let me know.
It does NOT work like that. Since the dimmer switch is a VARIABLE...a sliding scale, if you will. It's not simply on/off...there are varying levels of brightness.
Edit.........The only way it would work like that is if the dimmer switch, at it's brightest setting, grounds. Its worth a shot actually.
Ok, I just looked at the back of the dimmer switch and there is a blue/yellow wire back there. There is also a black/silver and red/(I forgot the tracer color) on the back of the dimmer switch. So the theory is that there should also be a blue/yellow wire behind the CC and If i ground that wire (we know 100% that this is a ground???), I should get "always on" CC lights?? Do I need to cut that wire or just tap into it? I am guessing cut it the ground the wire from the CC to a known hard ground point. Cutting that wire wont make me lose my dimming to the cluster right?
Dennis is right, I made it too complicated. At least as far as the relay method is concerned. For some reason I was thinking the bulbs were body grounded, with the dimmer adjusting voltage on the positive side (not the case). I still think the diode/resistor solution would still be the ideal way to do it, because it would retain dimmer control for all lamps while equalizing the brightness of the LEDs to match the rest of the bulbs in the circuit.
I spent some time checking out the diagrams for your 97.. In order to bypass the dimmer for the climate control, you need to cut the red/yellow wire from the two connectors and ground them. Seems weird saying that. All I ever do is work on 3rd gens, and R/Y for the 3rd gen is positive. On the 4th gen, it's the color of the resistant negative lead from the dimmer.
If other bulbs within the dimmer circuit are also too dim, you'll have to ground those as well. Which is why I think you should consider using a diode and resistor at the gauge cluster and call it a day.
Just spent some time checking the 4th gen diagrams. In order to bypass the dimmer for the climate control only, you need to cut the red/yellow wire from the two connectors and ground them. Seems weird saying that. All I ever do is work on 3rd gens, and R/Y for the 3rd gen is positive. On the 4th gen, it's the color of the resistant negative lead from the dimmer.
Done! Thanks to all who helped, especially hectic for looking at the fsm and giving me the right wire to cut.
There is one red wire with a yellow tracer on it behind the cc. Cut that wire, then run a direct ground from it to a good ground point. Pics will come in a bit.
This will override the Dimmer switch and make you climate control lights remain bright even if you dim your cluster lights.
Here is where you will be looking for the red/yellow wire. Behind the Manual Climate Control.
Here is the wire cut and stripped...you will be grounding this wire.
Here is where I grounded that wire to, but you can ground wherever you want.
How to Always Bright Manual Climate Control Maybe this can be added to the 4th Gen How to section?? I imagine there might be someone else who may want to do this.
I am up about 15 minutes east of waterville. yeah there's not many of us on here. And yeah, thanks for starting me in the right direction of the dimmer being a ground...I just realized you were the one that mentioned that and I didn't give you credit in my "thanks" post.
Is the black wire also a ground? If so, that may make it easier than having to unscrew the current ground i did if i want to remove the whole center piece...that way all the wires are still connected to the same harness.
tseng1023
10-15-2015 08:30 AM
DC_Juggernaut
09-28-2015 04:07 PM
