Ok, Here we go. I have an Awful noise that sounds like it is coming from the A/C compressor. When the car is on(At IDLE), there is a nya nya nya nya nya noise that sounds like a diesel would. I have no idea what would cause this noise, but it is getting worse and is driving me crazy. With an Intake and Exhaust, i can STILL hear this noise over my engine.
Thanks !
Thanks !
Is the noise present with AC on? Off?
Remove the AC/Alt belt. Run to confirm the noise is gone. Spin the AC clutch by hand to check the clutch bearing. Spin the Alt to check it as well.
Originally Posted by asand1
Is the noise present with AC on? Off?Remove the AC/Alt belt. Run to confirm the noise is gone. Spin the AC clutch by hand to check the clutch bearing. Spin the Alt to check it as well.
the noise gets so much louder and noticeable with the A/C Off
I will pull the belts today, but im starting to think its the TC tensioner... Which i HOPE it is not.Originally Posted by asand1
Quote:
Thanks !
A/C compressor bearing is failing.Originally Posted by demon_maxima
Thanks !
Quote:
You hit it on the nail. i pulled the belt friday and spun the pulley...shakes a bit and you can hear it rattle. Thank GOD its not the timing chain tensioner!
Quote:
Just swap over the bearing and clutch assembly. You will not need to release the freon to do this.Originally Posted by Doughboy89
Damn, I just sent my parts car off with a good compressor. Didn't want to let the refrigerate out in my garage.
You can use a steering wheel puller to remove the pulley assmbly from the unit. You will need to watch out as there's not a lot of room but a trick around this is to pull the 4 mounting bolts, drop the unit down then replace the top two bolts in the bottom holes. Gives you more room to work. I suggest an FSM if you don't have one. Will give you the exploded view of the AC compressor ... there's a small "C" clip in back of the pulley, holds the bearing on. Not a bad job really ... doing an engine is worse IMHO!
Cashoit !!!! Sup Bro!
Quote:
Freakin new compressor costs more than replacing the engine lol
I say thank god because its not engine- Threatening, Since i am still in highschool and live with my mom and she still thinks that anything that goes wrong with the car is my fault(Wont let me pull engine), and there is a write up on how to do it right here:Originally Posted by cashoit
what do u mean thank god???Freakin new compressor costs more than replacing the engine lol
http://www.vqpower.com/v2/articles.php?article_id=112
Quote:
Damn straight.Originally Posted by JtzMax
