No Spark on #6
Old Jan 4, 2002 | 01:48 PM
Ginuwin3112
No Spark on #6
i was testing my spark plugs out and the #6 cylinder has no spark...what are all the possible things that could affect the spark plug from making a spark?? (wires,ecu,ignition, etc...thanx~!
Old Jan 4, 2002 | 01:50 PM
Jeff92se's Avatar
I'm needing a caw
1) Bad plug. Switch plug for another and repeat test
Old Jan 4, 2002 | 02:04 PM
Sprint's Avatar
2) Bad Coil Pack.. switch with another coil pack and repeat test
Old Jan 4, 2002 | 07:16 PM
Ginuwin3112
I tried that..and i found out the 2 cylinder isn't getting any spark either..i'm thinking it's the ecu??? doesn't that control the sparks???
Old Jan 5, 2002 | 06:47 AM
1MAX2NV's Avatar
There are few things that could be wrong.
First...do you have a check engine light?
Things that could be bad.
ECU
Crankshaft position sensor
Condensor
Ingition coil
Here's what you need to do to diagnose.
Get a multimeter.
There are three wires going into each coil pack. Red, Black and another color wire with stripe on it. Do this...Make sure you get +12V from the Red wire at all times. Make sure the Ground is good by checking continuity. The color wire with a stripe on it is the ignition signal from the ECU.
Old Jan 5, 2002 | 06:52 AM
Ginuwin3112
Hmm...I will have to try that..I'm thinking it's my ecu because my check engine light doesnt come on at all
Old Jan 5, 2002 | 12:57 PM
Ginuwin3112
I think i have to get a new ecu..mine looks really bad because somehow water got into it and rusted out some stuff
Old Jan 5, 2002 | 04:48 PM
maximumsportZ's Avatar
Lives in a 350Z
testing your plugs??
How is that done?? sounds good.
Old Jan 5, 2002 | 04:59 PM
1MAX2NV's Avatar
There are about $150 from a junkyard. Just make sure you tell them exact model. EX. 1999 SE, cali-spec, Auto, no-traction control and non-abs brakes.
Old Jan 5, 2002 | 06:46 PM
Ginuwin3112
Can't I just get an ecu from any 4th gen. and take it to the nissan dealer to have it reprogrammed to my specs?
Old Jan 5, 2002 | 07:27 PM
1MAX2NV's Avatar
You got me. I don't know if Nissan can reprogram it. You might want to ask the dealership about that.
Need help
23
Oct 2, 2015 08:56 AM
Gingerheadman
Oct 1, 2015 05:11 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
cruce91
Sep 20, 2015 10:23 AM
