65 points away from passing smog. fed spec in a cali world.
Old May 7, 2012 | 11:35 PM
Raiom's Avatar
Got around to my maxima again. Didn't pass smog last year because my no(ppm) was at 868 when it was suppose to be under 507. So i checked the codes and it said egrc selinoid and rear o2 sensor. first I Fixed the broken flex pipe by welding a new one on and that took care of the rear o2 sensor code then I Bought the egrc valve for code 1005 and that cleared that code. Got back from smog and now I'm at 572. I decreased by 300. I have no check engine light on and the car runs and idles nice. Anyone have any suggestions. I'm 65 points away from passing. Car has 225,000 original miles.
Old May 8, 2012 | 01:51 AM
J2FRESH's Avatar
no other codes being thrown? everything is stock? original 225k miles on the car and etc.?
Old May 8, 2012 | 07:33 AM
Raiom's Avatar
Yeah no other codes,nothing. Everything stock on this one. I'm just lost on this.
Old May 8, 2012 | 07:36 AM
aackshun's Avatar
Seafoam it? *shooting in the dark here*
QT1 5MT AE's Avatar
Gram Lights addict
seafoam
Old May 8, 2012 | 07:39 AM
aackshun's Avatar
Also GOOGLE says that high NO(ppm) is caused by high cylinder temps or combustion hot spots.
Which the cause can be sitting in traffic for that long or the buildup of carbon in your motor....
Old May 8, 2012 | 07:41 AM
Rods03Max619's Avatar
Have you checked the main cat and pre cats, once on my 02 and 03, my main cat had nothing in it just like a Test Pipe, i would check that out since its more easier than the pre cats....GL..what part of Cali.....
Old May 8, 2012 | 08:08 AM
Raiom's Avatar
You guys read my mind, I seafoamed it yesterday through the intake got no white smoke like I did with my Mitsubishi. Sacramento Cali. Thanks for the help. I don't know if I should replace o2 sensors , I don't have a code for them so I'm up against the wall.
Old May 8, 2012 | 08:45 AM
aackshun's Avatar
By chance... Humor me here... Where did you suck up the seafoam?
Old May 8, 2012 | 08:53 AM
Raiom's Avatar
The new seafoam bottles have a hose that let's you slide it in before the throttle body plate.
Old May 8, 2012 | 11:28 AM
asand1's Avatar
This. Check you cooling system, drain your coolant and run 70/40 mix with a new tstat. Are you certain the EGR works in every aspect? Clear passages, good solenoid and valve? EGR reintroduces burned (inert) combustion gasses into the cylinders to lower temps.
Old May 9, 2012 | 11:08 PM
Raiom's Avatar
I'll check coolant again. For humor and fun I will post a video of that gtp stuff see if it works. Hahaha
Old May 10, 2012 | 08:12 AM
QT1 5MT AE's Avatar
Gram Lights addict
best way to seafoam is through the brake booster hose. id drop a full bottle in the gas tank too. or even a bottle fo bg 44k.
Old May 10, 2012 | 09:17 AM
Phromethius's Avatar
I hate the EGR system with a passion. There are like 50 solenoids and valves and its a pain to track down a problem.
You want codes? ....Yeah I got codes.
Old May 10, 2012 | 10:11 AM
cjandura's Avatar
easy way to pass E test is to run GT race fuel 104 octane just get a 1/4 tank if your on empty that is
Old May 11, 2012 | 04:50 PM
Raiom's Avatar
So I add the race fuel to existing gas or empty first?
Old May 12, 2012 | 07:21 AM
T_Behr904's Avatar
Back when we used to have emissions here in Florida, a friend of mine showed me this neat trick to pass the sniffer test. He would run his tank close to empty, and then add a couple of gallons of denatured alcohol, and then go and get tested. Passed with flying colors every time.
Now, all you have to do is go to your closest E85 pump and do the same thing, since it's 85% ethanol. Run your tank as empty as you feel comfortable with, and then put enough E85 in your tank to give you a 1/4 tank. Then go get your sniff test done. Report back to us your new sniffer reading after you pass.
After you go and do your sniff test, go to a gas station and fill your tank (with premium, preferrably Shell V-Power) to dilute the E85 since it's not good for non flex-fuel cars to use it.
Old May 12, 2012 | 07:45 AM
jholley's Avatar
Three years ago I failed emissions with all OEM exhaust. After throwing in a few gallons of high ethanol gas I kept her running in the lot for ~30min while I waited for inspection and it worked.
jmlee44
Oct 2, 2022 02:13 PM
gigabyte
Jan 6, 2017 06:05 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Quickywd01
Sep 21, 2016 09:36 PM
