too much tranny fluid ? what will happen?
Old May 10, 2012 | 07:10 PM
hangout's Avatar
I have the 97 Maxima SE auto.
I recently change the tranny fluid to the car, My friend putted 5 qts back in after we drain the fluid out.
I found that may be too much fluid we filled back in.. I check the fluid level when the car is cool, it's even higher than high/hot marking.
I think we should just put 4 qts in..
now what will happen to the car? any idea?
Old May 10, 2012 | 07:14 PM
Amerikaner83's Avatar
too much fluid is just as bad as not enough. Drain until you have the proper fluid level. You should put back in the SAME amount you drained. Did you not measure?
Old May 10, 2012 | 08:11 PM
ShocknAwe's Avatar
Its hard to get a good reading though. I drained more than I wanted putting in a cooler and put in a lot less than was drained and it says its high. Tested multiple times using hot and cold. Just like the oil dipstick, a good reading is hard to get
Old May 10, 2012 | 08:31 PM
maxed_out_99's Avatar
just a rule of thumb;
check the fliud with the trans warm and the engine running in park.
the torque converter drains while its not runing cause the level to go up
the fluid also thins out when its warm
Old May 11, 2012 | 06:18 AM
GStrength's Avatar
yea take this man's advice.
Old May 11, 2012 | 08:34 AM
Snypa's Avatar
just overflow thru dipstick. Check level...while car is running.
Old May 11, 2012 | 09:16 AM
asand1's Avatar
If's high enough, it can froth. This will cause it to lose its hydraulic properties and result in clutches and bands slipping. Also foamy ATF will not protect your bearing surfaces from contacting the metal surfaces.
Old May 11, 2012 | 09:24 AM
jholley's Avatar
+1
Checking it warm is the best way to read the ATF level.
What some of you don't know is when checking the cold markings on the dipstick you still need the engine running but on a cold start. If the engine is cold and turned off the ATF will be far above the cold markings.
EDIT:
Whether you're reading the COLD or HOT markings on the dipstick the engine needs to be running.
Old May 12, 2012 | 10:28 AM
steezmuffin686's Avatar
id suggest running the car thru each gear with tires off the ground engine running after filling up. go thru all the gears slowly and let each gear run for 30-45 seconds to make sure fluid's gone thru all the clutch packs..idk, might help.
HOKUSMAX
Nov 13, 2017 04:34 AM
fx4five
Oct 18, 2015 06:57 PM
Need help
23
Oct 2, 2015 08:56 AM
fx4five
Oct 1, 2015 04:58 AM
