How much to repair this?
Old May 19, 2012 | 09:57 AM
Pilot8680's Avatar
My car was hit while parked on the street. What will the cost be for repair?
http://s1167.photobucket.com/albums/...nt=MaxDent.jpg
Old May 19, 2012 | 10:15 AM
Search a junkyard for a used door and fender in your color.
Old May 19, 2012 | 10:27 AM
tigersharkdude's Avatar
$1,487.26
Old May 19, 2012 | 10:30 AM
Amerikaner83's Avatar
Ouch...worse than what I was expecting...
How much it costs you depends on how you want to fix it...if you want to do it yourself...go to a junkyard and find stuff in your color if you're lucky...or buy automotive touch up paint and paint a new door your body color....or take it in to a shop and drop about a grand.
Old May 19, 2012 | 10:33 AM
infinimax96's Avatar
cheapest will be to find matching door and fender at junkyard. I'm sure body shop would charge at least $1500 to fix something like that.
Old May 19, 2012 | 10:35 AM
GGENIUS's Avatar
if you go to a shop, that estimate tigershark gave you is def on the low end of things even. you could either get it fixed right for 1.5-2Gs, or just get a new aftermarket fender and beat that door back to a 95% repair. if you find someone who does side body work jobs(like me) you can cut corners to save money.
Old May 19, 2012 | 11:15 AM
MAXIMA_STYLE's Avatar
You guys are nuts... new fener is 80-100...jy door...shop to paint and install...totaling 800-1000
Old May 19, 2012 | 11:16 AM
Pilot8680's Avatar
I just need someone to remove and realign the fender to the door and to the hood. Right now the inner liner is rubbing against the tire and the door is making contact against the panel when it opens. Getting it repaint is the least of my concern.
What would you charge for a side job like this and how long would you take?
Old May 19, 2012 | 11:28 AM
GGENIUS's Avatar
well, you could do that if the mounting points on the fender havent been ripped off/open. it looks as if the bottom ones have been, in which case it would have to be really ghetto rigged to even come close to lining up. i would def recommend a new fender, like that guy above said(because aftermarket fenders are literally 100 bucks at the most). but another problem is that door is going to rust to **** now without atleast primer on it. but then youve got a big ugly primer spot.
if i were just to band the door back to 95% and replace a fender without any paint, id charge like a hundred bucks labor probably. around that area. and it wouldnt take more than a day really. with some primer itd be a tad more.
Old May 19, 2012 | 11:33 AM
GGENIUS's Avatar
no, were not nuts. the high estimates in this thread are talking about getting it fixed RIGHT. a body shop doing this job the right way would be blending the rear door and also the hood, on top of the fact that there is likely to be SOME damage to an LKQ door you get from the junkyard(scratches, dings, what have you)... which would need to be fixed before painting.
Old May 19, 2012 | 11:54 AM
Pilot8680's Avatar
I'm in Queens, and your willing to do the job out of Trenton, NJ?
Old May 19, 2012 | 12:13 PM
GGENIUS's Avatar
yeah but thats gonna be a little hard to do because of my schedule. pm me.
Old May 19, 2012 | 12:19 PM
99SE-L5SPEED's Avatar
fender coast 15 and door whit pannel and window everthing coast 25 at my junk yard and they have ur color in pa
Old May 19, 2012 | 12:23 PM
if u in nj i can get the info for u and u can come get them ur self i can even tell u how to put them on this guys are nuts a shop out in my town will do it for 250 pantied and all
that door can be fixed and the fender is cheap
Old May 19, 2012 | 12:24 PM
o u in ny u about 1.45 min away im from ny to but live out in pa now
Old May 19, 2012 | 12:25 PM
if u come 40 on parts and 70 to get over and back to ny
Old May 19, 2012 | 12:28 PM
GGENIUS's Avatar
yeah, def listen to this guy ^
Old May 19, 2012 | 01:36 PM
maxfever1987's Avatar
I'm in queens call me 917-442-1775 I have that same color fender and door
mkaresh
Mar 12, 2018 06:48 PM
MichMaxFan
Sep 30, 2015 09:18 AM
lux97Max
Sep 28, 2015 11:18 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
dcam0326
Sep 8, 2015 11:02 PM
