Engine Help VQ30DE
Engine Help VQ30DE
Full story, my moms maxima had a bad fuel injector in cylinder 4. The engine hydrolocked from filling up with fuel. I got all the fuel out and went to crank and it was not turning over. I manually cranked it very slowly for a few minutes for it to become free. After that, the engine fired up. Now there is a new problem. When the car reaches operating temperature, white smokes comes out of exhaust.
There is no coolant/oil contamination from engine oil or radiator. The smoke smells like oil. I am leaning towards the rear main seal because from cold, the car starts fine and does not smoke. When temperature gauge reaches half way is when the smoking starts. Any suggestions?
I had the same issue this weekend. White smoke with no oil/coolant mix in the oil pan or radiator. Engine passed compression test on all cylinders. Added a couple quarts, let the car run for a few minutes and noticed my rear main seal was leaking pretty bad. Now I'm looking for a mechanic that doesn't want to rape my wallet...
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
