99 Maxima Short whine when started
Old May 19, 2012 | 06:40 PM
Fusion235's Avatar
Hi people.
Question, my 99 G Maxima, has 165k on it, just in the last week, when cold in morning and you start the engine,
You get a quick short whine/moan from engine bay somewhere, also - sometimes, not all the time but if you dont give it a quick rev it will die instead of going to normal idle straight away , othertimes its fine.
I am suspicious of the starter motor, but also of the alternator, who knows maybe its both, car seems to run fine after that initial thing and I have not seen the battery light on at all while driving. I dont think its a belt as it sounds different to to that kind of noise.
Any opinions would be appreciated!
Old May 19, 2012 | 07:32 PM
asand1's Avatar
Search for starter re-grease.
Old May 20, 2012 | 08:12 AM
Aanaya480's Avatar
Do you think it could be your water pump going? They always go with a whine, or maybe your ac clutch? Take a good look with the motor running same thing happened to me with my A/C clutch long story short it melted the plastic between my crank nd the crank pulley, it fell right off when the belt snapped, (it was a squeak from the ac clutch getting stuck)
Old May 20, 2012 | 06:39 PM
Snypa's Avatar
If it whines when accelerating = Alternator
Other things to check would be the starter and possibly a belt.
Old May 20, 2012 | 11:57 PM
Fusion235's Avatar
hnnnm could be, seems to still do it while AC is off, so im leaning toward pump or starter, its a bugger to fault find it as you only get it once while cold in the morning for like a couple of seconds then its gone, no whining while accelerating so I dont think its the alternator, plus i turned it on today and turned on the lights & tested the battery with a voltmeter and it reads just over 14 volts while running with lights so that would indicate thats working ok. The starter motor was recond like a year or so back, maybe its dying now lol.
kjlouis
Nov 24, 2018 06:09 AM
02PearlSE
Oct 7, 2015 02:12 AM
criminalslang810
Aug 16, 2015 08:12 AM
acw
Aug 13, 2015 12:50 AM
Jcof88
Aug 3, 2015 10:43 PM
