air temp sensor
Old Jan 5, 2002 | 08:33 AM
onefastmax's Avatar
air temp sensor
I need help... When I removed the factory air box on my 97 to add a cone filter, I relocated the air temp sensor after the MAF in the box. Now my check engine light won't go off. I've tried reseting it but it comes back on. Any suggestions are appreciated.
Old Jan 5, 2002 | 10:08 AM
ny96max's Avatar
most likely its cause you discontected your MAF not the sensor. Try doing a diagnostic check on the ECU. Its probably something else thats wrong!
Old Jan 5, 2002 | 01:00 PM
onefastmax's Avatar
I never moved or disconected my MAF. Simply removed factory plumbing and added the cone where the stock air box was. the only thing I touched was the air temp sensor by relocating it. Should the cone or shifting the temp sensor through the light? Or is there another problem at the same time?
Old Jan 6, 2002 | 05:48 AM
Micah95GLE's Avatar
My air temp sensor is taped to the shock tower right underneath the intake. I've never had a problem (and neither has anybody else here), so you must have another problem. You better get the diagnostic code from the Check Engine light.
Old Jan 6, 2002 | 06:20 AM
skeelo34's Avatar
I had the same problem when I installed my K&N cone filter. I heard that this might have happened, and I guess I wasn't worried about it. About 2 weeks later the engine light just went away by itself. I think I've read other posts with the same experience.
Old Jan 6, 2002 | 06:51 AM
maximus75's Avatar
Re: air temp sensor
Make sure you didn't leave any vac or air hoses disconected. It's prob not your air temp sens. It doesn't matter where you mount it as long as it can read intake air temp. There is a large hose that cames off the throttle body and goes to the air box. Make sure you didn't leave it off. That will set the light off right away!
Old Jan 6, 2002 | 07:14 AM
AznStevie's Avatar
does the temp sensor matter??? i got CAI, and my temp sensor is out there hanging and ziptied somewhere...and i found out that there is a pre drilled hole on my cai that's for me to put the air temp sensor in. if i leave the sensor out...will it affect my car's performance? thanks
Old Jan 6, 2002 | 07:22 AM
maximus75's Avatar
It is not a major input. If it is not in the path of the intake air but it is plugged in and hanging out in the engine bay it might slightly effect you fuel trim depending on the temp difference between the two but it wont do any damage. If you have a hole for it you should install it.
Old Jan 6, 2002 | 09:43 AM
Mishmosh's Avatar
Originally posted by skeelo34
... About 2 weeks later the engine light just went away by itself.
I thought CEL do not go off until reset... So even if you correct the problem, don't you have to reset the ECU?
Old Jan 6, 2002 | 06:37 PM
skeelo34's Avatar
I didn't think so either but someone told me just to wait, and it worked. Actually I spoke too soon. I was driving today and the freakin engine check light came on! Great, it reminded me of the post I made earlier today. I have no idea why it came on but I'm not gonna ignore it this time. So how do I check what it is? I'm too lazy to search.
Old Jan 6, 2002 | 09:50 PM
Eric L.'s Avatar
Are you sure it is the air temp sensor? Did you pull the code, or just assume it was the air temp sensor?
Old Jan 7, 2002 | 04:58 AM
onefastmax's Avatar
It was the air temp sensor but when I pulled the code it was my EGR valve tripping the light.
Old Jan 7, 2002 | 12:08 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
actually for the 4th gen, the intake temp sensor is not used to control fuel trim or anything else. its simply used for diagnostic purposes only. Go read someone's factory service manual and itll say in there.
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
bumpypickle
Sep 20, 2015 08:22 AM
conansriver
Sep 11, 2015 10:26 AM
lux97Max
Sep 4, 2015 05:42 PM
