Absolutely cannot remove the fuel filter. St Louis area anyone?
Ok I've tried 4 different times to remove the fuel filter on my Mom's '97 GLE (ABS). I can get the top hose off but no amount of twisting, turning, nothing will get the bottom broken loose.
I've tried everything I can find on here and elsewhere.
I'm kind-of near St. Louis, anyone done this on theirs and have a good technique that works?
I SHOULD MENTION THAT IT IS THE ORIGINAL FUEL FILTER. 157k, 1997 model.
I tried at 60k, 90k and 120k and just now to get it off.
I would say twist and pull but seeing that you have the ABS module blocking some of your workspace, I would do what the others suggest to crimp or replace the hose. Just put some oil on nipples of filter before sliding over hose.
I have found the trick to getting it off easier is to do it when the engine compartment is rather warm. Like 20 minutes after a good ride. The heat will make the hoses a bit softer and easier to work with.
Or you can get some shears.... Cut the old fuel filter where the nipple for the hose begins.
Use pliers to get the old nipple out of the hose....
It's what I did on my last FF change....
That's one I hadn't thought of, I've been trying it with the car cold. Thanks
Alternatively, you can do what I did. Work a 90* pick between the hose and the filter nipple all the way around to loosen it up. Then use a trim prying tool to PUSH the hose off the filter nipple. Pulling will only make it tighter.
RWCreative
09-21-2015 11:01 AM
