anyone have a write-up on install of upgraded headlight harness?
Old Jan 5, 2002 | 12:35 PM
ZXdude's Avatar
i'm not to sure what to make of this...
Old Jan 5, 2002 | 01:14 PM
Gotrice4's Avatar
Re: anyone have a write-up on install of upgraded headlight harness?
There is one connector that you connect to the maxima's headlights(stock) harness, so it knows when to turn on or off. Then there is going to be wires to connect to the positive and negative points of the battery. Then the two others sockets go into the new headlight bulbs you have installed in the headlights, then the two other wires that need to be grounded.
Or just go to MaximaDriver.com and click How2 and go to upgrade light harness.
Old Jan 5, 2002 | 07:24 PM
JAY25's Avatar
See if this helps
Grab those two black pieces out of the plastic and see the yellow part of the harness connect them in there.
See the blue piece unplug the left rear of your mainheadlight and plug that in to control when you
turn on the lights on and off. Now connect the two black parts to the rear of your Headlight bulbs.
now the black round things with a little round hole, find the nearest screw that touches the metal of the car,
remove the screw and place that in there. (Thats to ground it). Now see the two red wires
connect them to the battery. Your done it should only take you like 20 mins tops to this. Hope this helps Jaime
Old Jan 5, 2002 | 07:33 PM
ZXdude's Avatar
Re: See if this helps
thanks for the help i'm stylin with both lights on and the passanger side fog out
Old Feb 19, 2002 | 06:09 PM
Max96LSU's Avatar
Where did you get your upgrade harness from? And how much was it?
Old Feb 19, 2002 | 06:18 PM
Ravq's Avatar
Re: Re: anyone have a write-up on install of upgraded headlight harness?
If you're looking for one try this:
http://suvlights.tripod.com/suvlightscom/id11.html
Old Feb 19, 2002 | 06:23 PM
Sexima's Avatar
I would like to know this too..
and on my other post..
http://forums.maxima.org/showthread....3&goto=newpost
I need help...
My right harness (One near the battery) is busted up...
so what am I going to do?
Old Feb 19, 2002 | 06:26 PM
Max96LSU's Avatar
Re: Re: Re: anyone have a write-up on install of upgraded headlight harness?
I've tried calling them and emailing them, but they never respond. Do you know of any other places that might sell them. Is TNK motorsports any good? http://www.tnkmotorsports.com
Old Feb 19, 2002 | 06:32 PM
Ravq's Avatar
Re: Re: Re: Re: anyone have a write-up on install of upgraded headlight harness?
Suvlights.com is where I got mine from and their customer service was excellent in my case. Anyways, I know www.autodynamic.com sells them too.
vingodine
45
May 21, 2016 12:46 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
