Just installed camber plates
Old Jan 5, 2002 | 03:56 PM
maximus75's Avatar
Got them because I dropped the car about 1.5" and the front tires were were wearing a little funny. Anyone have these? What it the best camber setting. I can't find a spec for the car because it's not adjustable.
Old Jan 5, 2002 | 04:00 PM
araffio's Avatar
Re: Just installed camber plates
An alignment would have been sufficient probably. You don;t really need camber plates unless your dropping the car 2" or more.
Old Jan 5, 2002 | 04:03 PM
maximus75's Avatar
Re: Re: Just installed camber plates
I lined it up and everthing was in. I plan on lowering the car more when I get coilovers. Anyway, do you have any specs?
Old Jan 5, 2002 | 07:03 PM
mzmtg's Avatar
Minister of Silly Walks
Th idea is that you can use the plates to get back within factory specs when you are lowered. Any alignment shop will have the factory specs...
Old Jan 5, 2002 | 07:23 PM
1MAX2NV's Avatar
Get an alignment at a shop that worked with camber plates before. They will know what to do. Expect to pay alittle more than your usual alignment shops. I say anything between $60-$90 is reasonable.
Old Jan 6, 2002 | 06:23 AM
maximus75's Avatar
I have an alignment machine at my shop but it doesn't have camber specs for my car.
Old Jan 6, 2002 | 06:43 AM
redmaxpa007's Avatar
i SeE what you did therE
this is from the all mighty himself....
This information is from the '99 Maxima factory service manual. I believe it also applies to your '98.
FRONT WHEEL ALIGNMENT
Camber, in degrees.
-1.00 Minimum
-0.25 Nominal
+0.50 Maximum
+0.75 Maximum left and right difference
caster, in degrees
+2.00 Minimum
+2.75 Nominal
+3.50 Maximum
Kingpin inclination, in degrees
+13.50 Minimum
+14.25 Nominal
+15.00 Maximum
Total toe-in distance, in millimeters
+1 Minimum
+2 Nominal
+3 Maximum
Total toe-in angle (left plus right), in degrees
+0.09 Minimum
+0.18 Nominal
+0.27 Maximum
REAR WHEEL ALIGNMENT
Camber, in degrees
-1.75 Minimum
-1.00 Nominal
-0.25 Maximum
-3 Minimum
+1 Nominal
+5 Maximum
-0.27 Minimum
+0.09 Nominal
+0.43 Maximum
__________________
Daniel B. Martin
Nissan owner and D-I-Y mechanic
Old Jan 6, 2002 | 06:56 AM
maximus75's Avatar
Camber, in degrees.
-1.00 Minimum
-0.25 Nominal
+0.50 Maximum
caster, in degrees
+2.00 Minimum
+2.75 Nominal
+3.50 Maximum
+13.50 Minimum
+14.25 Nominal
+15.00 Maximum
+1 Minimum
+2 Nominal
+3 Maximum
+0.09 Minimum
+0.18 Nominal
+0.27 Maximum
Camber, in degrees
-1.75 Minimum
-1.00 Nominal
-0.25 Maximum
-3 Minimum
+1 Nominal
+5 Maximum
-0.27 Minimum
+0.09 Nominal
+0.43 Maximum
__________________
Daniel B. Martin
Perfect. Thats just what I needed. My alignment machine won't give you specs for something that is non-adjustable but will let you manually enter specs. Thanks!
Old Jan 6, 2002 | 06:58 AM
no problem!!
Old Jan 6, 2002 | 07:04 AM
maximus75's Avatar
no problem!!
I was just checking out your site 007. I saw you at LSP. How do you like you brake setup? I can't afford the Stillen big brake setup and I'm going through stock pads like crazy. BTW- I love red max's. They were'nt out when I got mine.
Old Jan 6, 2002 | 07:13 AM
i like the brakes.. $tealin slotted rotors and Axxis Metal MAster pads... i like them.. i know ANDYXXL had issues with the pads.. but i think he had defective pads..
i wish i could afford a big break kit... they make MADDDD brake dust.
i drove my maxima off the show room floor with 3 miles on it. there were 4 red maximas at the dealership when i bought mine!!
LSP was my first meet.. i was overwhelmed... i was like.. "whoa" this is a normal meet? damn..... cause there are only like 3 or 4 org member in my area...
Old Jan 6, 2002 | 07:28 AM
maximus75's Avatar
LSP was my first also. I think you were the only Red max there. It's cool to meet up with the people you talk to every day. And it feels goodto know your not the only person obsessed with you car. I just heard something about a meet in Atco but I don't know were that is. I live on Long Island.
Old Jan 6, 2002 | 07:37 AM
Vinipux's Avatar
COUNT ME ON THE AXXIS METAL $HIT BRAKES HATE CLUB
dude, I race my car and i cannot stand the brakes, they are okay on the first couple of runs, but after that, they're aweful, they fade and you can't brake the car for your life, also, they make terrible noises on the street, and lately I seem to have a problem that if I slam them hard from high speed, after that they make really bad noise when braking???? that seems weird
p.s. I autocross for racing
Vinipux
Old Jan 6, 2002 | 07:46 AM
maximus75's Avatar
Vinipux
There aren't too many options out there as far as brakes go. Maybe I'll save up for the big brakes. You auto cross so you would know this. Should I set my camber to factory specs or could I benifit by giving it a different setting?
Old Jan 6, 2002 | 07:51 AM
i autocrossed with them as well.. i loved them!! sorry.. BUT i am all for the pads!!
Old Jan 6, 2002 | 07:56 AM
Vinipux's Avatar
I would get portefiers, they're 118 group deal on the www.maximadriver.com, not too shaby, my friend who races loves them, also get SS brake lines, I Hear that works well too, I'm installing them in the spring
as for the camber, for street driving, set it to factory, for racing you want negative camber, but even then I wouldn't worry about it
Vinipux
Old Jan 6, 2002 | 07:57 AM
maximus75's Avatar
What to do????
Old Jan 6, 2002 | 08:06 AM
Vinipux's Avatar
What to do????
get SS brake lines (only really need 'em for racing)
get the portefiers brakes, R4S they are street/racing, so they don't need warming up to work well, but I hear they're awesome
and that's all you should do
and have a shop set your camber plates to factory setting
Vinipux
Old Jan 6, 2002 | 08:09 AM
maximus75's Avatar
What about rotors. Mine are shot.
Old Jan 6, 2002 | 08:13 AM
Vinipux's Avatar
get the nissan rotors, personally, I don't believe that stillen rotors will give you enough to make it worthwhile getting them, unless you're racing 1/4 of a foot will not matter, save yourself some $$$ and get a stillen sway bar or something
Old Jan 6, 2002 | 08:20 AM
maximus75's Avatar
Thanks for the input
Old Jan 6, 2002 | 08:24 AM
Sprint's Avatar
gotrice has an awesome brake deal on his page.. you can't beat the price..
http://www.eatricezone.com
oh.. btw.. their were two red maxima's.. jeff and bluefish
Old Jan 6, 2002 | 08:28 AM
bluefish is not a ~~POST PIMP~~ like me...
Old Jan 6, 2002 | 08:33 AM
Vinipux's Avatar
he doesn't have portefiers
http://www.seas.ucla.edu/~cheston/mdgroupbuy.html
go here, it's $118
Old Jan 6, 2002 | 08:41 AM
Sprint's Avatar
go here, it's $118
i wouldn't buy those.. they dust like crazy..
besides.. $118?
did you see the deal from got rice?
$540
NIS4000, front rotors,
NIS4002, rear rotors,
Axxis front pads,
Axxis rear pads,
Goodridge SS brake lines,
Motul 600 brake fluid, 1/2 liter
Old Jan 6, 2002 | 08:46 AM
Vinipux's Avatar
portefiers dust like crazy?????????
well, have you seen how axxis pads dust??? they dust like super crazy
besides, I'm sure you can get all this cheaper seperately
Old Jan 6, 2002 | 08:49 AM
Sprint's Avatar
porterfields dust more than ANY pad for the maxima.. they have great stopping power.. but this is their biggest complaint.. YES they dust more than axxis..
my car has white rims.. i have trouble as it is now .. cleaning the wheels every 4 days during the summer.. if i had Porterfields.. i would be cleaning them every day..
i am sure you can find anything cheaper if you look hard enough.. but if you can.. let us know..
Old Jan 6, 2002 | 08:53 AM
i have to agree with sprite..err i mean Darren.
Phuong has some of the best prices.. and i also agree with the brake dust
Old Jan 6, 2002 | 12:05 PM
iwannabmw's Avatar
Yep, Porterfield's dust like a mother, but they can stop the car from 100+ speeds with no fade(unless running a road course). You can get the front set of pads for only $69 bucks, you don't really need the rear, they hardly do anything. As for the camber, Vinipux is right, go with factory for street driving. If you make the camber too negative, you will greatly accelerate your tire wear, but you'll stick in the turns much better!
Vinipux, those were metal matrix pads you got smoking like that? They smoked so much I thought they were stock Ouch, remind me not to ever buy those!
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
Maxima Pride '07
Sep 12, 2015 07:29 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
