MT or AT for VQ35 Swap
Old Jun 1, 2012 | 03:59 PM
cDgRazoray's Avatar
For reference, I have a 1995 Maxima SE with a blown head gasket and RMS. So I want to upgrade to a VQ35. My understanding is as long as its a FWD VQ35 it should just bolt right in. I'm not too sure about the transmission and hope you guys can point me in the right direction.
Hey guys so I found a VQ35 with only 25k in my price range, problem is it comes with an automatic transmission. I really wanted a 6 speed which would have been fun. Should I suck it up and get the AT? Would it be easier? Or should I keep looking for one with a MT? Will the new tranny require new mounts and axles? Or will everything bolt right up? I've searched but couldn't find someone with a similar situation. Thanks
Old Jun 1, 2012 | 04:20 PM
Rods03Max619's Avatar
Should check the All Motor Section, but from what I read I believe the VQ35 will bolt up to the transmission with no problems, if you are MT look for a MT and if AT go with AT, unless you are planning to swap out the Transmission also...
Old Jun 1, 2012 | 04:59 PM
cDgRazoray's Avatar
ya I figured itd be easier to just get a VQ35 with a transmission and replace both at the same time. Will a 2006 Manual transmission just bolt right in? or is an automatic easier?
Old Jun 1, 2012 | 06:28 PM
Nealoc187's Avatar
SLOW
the vq35 doesn't exactly bolt in without any work on your part. you need to either swap timing equipment on the engine, or rewire you 4th gen to use the VQ35 ecu.
same with the 6spd trans. significant (but not insurmountable) changes are required. changing from rod linkage to cable linkage is chief among them.
a 4th gen trans will bolt right to the VQ35 though, if you decide to go that route.
Old Jun 1, 2012 | 09:59 PM
carsnwomen91's Avatar
hahaha
so (basically) i (5spd) can get a fwd vq35de from anything and drop it in and change to 3.0 timing and thats it?
wanna link me the proper thread?
Old Jun 2, 2012 | 09:39 AM
Blackwind's Avatar
hahaha
No. It's in the all motor section.
Old Jun 2, 2012 | 10:28 AM
Product_Of_Korea's Avatar
hahaha
Little more entailed then that. But the majority of the swap is the timing components and actually dropping it in and taking it out.
Old Jun 2, 2012 | 11:09 PM
deloa84's Avatar
Go with a manual. If you are also doing the timing swap from the 3.0 stick with a 4th gen 5 speed trans. That is what I have in my 3.5 swap and it is a blast to drive!! Plus those 5 sp trans can be found easily and for cheap.
Old Jun 3, 2012 | 07:16 AM
mmk i'll go look for it lol
cool, i'ma read about it and if its "easy" enough i might want to do this in a couple of years.
Old Jun 3, 2012 | 10:45 PM
97vqi30's Avatar
i know having the MT would be better but is there really a big disadvantage with having an auto 3.5 swap versus a MT? i know the 3.5 engines really hustle harder in the 4th gens.
no intention on thread jacking sorry
Old Jun 4, 2012 | 09:03 AM
http://forums.maxima.org/all-motor/4...swap-info.html
Old Jun 4, 2012 | 07:59 PM
TravisCadello's Avatar
the 3.5 motor will bolt to the 3.0 A/T BUT from What i have heard is even if ur soft on it the trans wont last but a couple months just because the low end torque the 3.5 Makes. so deff Dont go that route.
Old Jun 4, 2012 | 08:20 PM
cDgRazoray's Avatar
Thanks for the suggests guys. Just waiting on the shipping costs for a 2006 VQ35 + AT with only 25k miles. Hopefully will be ordered tom.
Old Jun 9, 2012 | 02:47 PM
cDgRazoray's Avatar
Wanted to update you guys without making a new thread. I bought a matching 2002 VQ35 with the AT with only 25k miles! Should be shipping this Monday and I'll start the swap this coming Friday. So stoked.
Old Jan 22, 2024 | 03:51 PM
Kadinmcclure22's Avatar
do I need to change out the ecu or anything electrical to put in a 95 trans in my 04 maxima? Or will it just latch up and that’s all?
Old Jan 22, 2024 | 04:07 PM
RA030726's Avatar
I'm nutty for Nissans
Not going to work.
Old Jan 23, 2024 | 07:04 AM
Originally Posted by JSutter
Not going to work.
he said the 4th gen should bolt right up to the vq35?
mid nit do you know if a transmission that I can swap in to build power?
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
mclasser
22
Nov 12, 2020 01:58 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
