engine shaking/pulsating - need help with diagnosis
Old Jun 9, 2012 | 09:09 AM
tarun900's Avatar
Hi guys, originally had this problem over a month ago when I was in another state back in college....It only happens when I'm idling in drive or reverse but it's like engine shakes/pulsates every so often. I first thought it was jut the car being old and the transmission being whiny or something. Fast forward a month later to now....I've driven 650 miles to another state for my summer internship and been driving over 200 miles a week. It was last week and primarily yesterday when this pulsating/movement of the engine got really noticeable. An hour later, the SEL came on. Gonna take it into autozone today to get the code checked for free, bu I was wondering beforehand if anyone here had any ideas n what s causing this shaking. I red a lt f old threads, and it doesn't look like a misfire because I haven't noticed a drop in performance while driving (none that I've noticed anyway) and the fuel efficiency hasn't changed either as far as I can tell. So anyone got any clues?
Old Jun 9, 2012 | 11:11 AM
DennisMik's Avatar
It could still be a coil or a fuel injector. They can fail at idle but still work at higher rpms before it died all together.
Old Jun 9, 2012 | 11:51 AM
tarun900's Avatar
Okay got code read at Autozone...P0301 - misfire cylinder 1.
Old Jun 9, 2012 | 11:57 AM
maximan85's Avatar
word man i feel you on that i have the same problem as well it shakes on idle and sometimes reverse it goes and leaves from time to time not sure what it is i changed spark plugs thinking that was the problem but it wasint i havint changed coiles yet but would really want to fix this just as much he does so please any info would be good for us
Old Jun 9, 2012 | 01:14 PM
njmaxseltd's Avatar
Replace the coil pack on cylinder #1
Old Jun 9, 2012 | 01:45 PM
AMP14's Avatar
I would switch the spark plugs too, unless you know yours are in good condition.
Old Jul 7, 2012 | 03:28 PM
gershon's Avatar
My 1995 Maxima engine started running really rough, my mechanic diagnosed a bad injector #6, replaced it and now it is smooth *most of the times*. But now I have the same exact symptom as tarun900 = engine shakes / pulsates intermittently while idle in drive or reverse, runs just fine on neutral or park. Does not happen while cruising, at least I can't feel it happens then. No engine check light yet, my mechanic saw no code in the ECU either, suggested I keep driving it until a code shows up. Can it be the new injector needs a new coil as well? Does it sound like a coil problem and if so how does someone diagnose coil problems without engine codes?
Old Jul 7, 2012 | 06:14 PM
DennisMik's Avatar
To find out which cylinder is having a problem, you have the engine idling and then unplug the wire harness connector from the coil packs one at a time. If the engine does not idle worse when you unplug the wire, then you have found which cylinder is having the problem. Now you have to determine if it is a coil or the fuel injector or a spark plug. You can swap the coil pack with another cylinder and then see if the problem follows the coil pack.
If the engine is running smoothly, then this will not show you anything.
Old Jul 8, 2012 | 04:06 AM
Trini Boom's Avatar
Inspect your spark plugs as well.
Old Jul 8, 2012 | 05:58 AM
rf97's Avatar
How is your alternator. I it's a long shot, but b4 mine quit, my idle would fluctuate between 5 and 5.5. With new alternator in idle is back up to 6.5
Old Jul 8, 2012 | 06:02 AM
rf97's Avatar
Just wrap the base of coil pack 1 with good quality electric tape and see if that solves your idle problem.
Old Jul 8, 2012 | 11:31 AM
Maxieggy's Avatar
I have the same problem, it seems to get worse when I turn on my headlights at nite...any thoughts?
Old Jul 9, 2012 | 07:42 PM
gershon's Avatar
So today my check engine light came On and stayed On. I flashed the codes. 0302 and 0304 = both #2 and #4 cylinders misfire. Very strange. It feels like a misfire problem as the engine pulsates and shakes intermittently but runs OK otherwise. Still they only replaced injector #6. What else could have happened to bring about misfiring in 2 different cylinders?
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
jcvgn
Sep 10, 2015 08:03 PM
