Alternator ain't easy to chg.
Man, that alternator is not difficult at all. Even replaced one during the winter outside it was that easy. Just a ratchet and a 14mm is all you need. Hardest part is guiding the alternator in and out with the compressor there.
All You Guys Scare Me,Like when mine went out i read on here a few guys saying they were really hard to change...well Come To Find Out if u do it like i did by my dam Self their was Absolutly notthing hard about it at all and i got huge hands....
1-Drain Radiator.
2-Remove upper Radiator Hose
3-remove lower hose
4-loosen tension pulley bolt slightly & loosen the adjuster to remove Belt.
5-remove 4 13mm Bolts holding AC Compressor in Let it rest on a bench about 6 inchs below its home.
6-Remove Alternator Harness And Ground And Upper Bolt.
7-Then Remove the Really Long Bolt From Bottom Of car. Wiggle Alt Till u get it out from beneth the car.
I've done about 4 of them by now notthing hard to it what so ever.
1-Drain Radiator.
3-remove lower hose
1-Drain Radiator.
3-remove lower hose
1-Drain Radiator.
3-remove lower hose
No need to remove the radiator. I did an alternator in less than a hour with an extra set of hands. It's just an annoying amount of weight at an awkward position. I have a refurb Advance auto alternator in my car. Running strong !
Agreed.....Water Pump is a JOB From Hell n back and Guaranteed,Busted Knuckles,Throwing of tools,Cussing the Wife when she asks u if she can help,and a few trips back to the ORG for Help. haha
I took it out from up top, I couldn't imagine taking it from the bottom. The reason you need to move the AC compressor is because otherwise its impossible to get to the the main bolt... at least it was impossible for me, I have big hands. I did this just two weeks ago and when I was trying to bolt the new one back in I stripped the threads on the J nut. I went to the Nissan dealership and they wanted $12.50 for that nut, and I couldn't find it anywhere else. So I fabricated my own for 75 cents and it worked just fine ... Lesson of the story: don't work on your car angry or you'll start breaking things.
well after i took the last bolt out, i just slipped it out through the bottom while i moved the compressor out of the way. i also put the new one in via the bottom. i put it in its general area, and then moved the compressor back underneath it, and let the alternator sit on top of it.
I replaced my alt in 05 or 06. It was pretty straight forward. I dont have the splash shields under the car, so that saved time. I remember picking up the front end by the wheel well and kicking the alt under the car. I was pretty low at the time and the lip did not help. That was probably the hardest part. lol
lol
lol
Yeah I've had mine off for a few months now and I haven't had any trouble so far. What I'm worried about most is something get caught on my accessory belt and ripping that off... what would be really nice is if there were aftermarket splash shields made off aluminum with decent fittings to the otehr pieces underneath the car. The only reason I leave mine off is because whenever I go to take them back off after putting them back on I always seem to tear through another plastic piece.
TallTom
50
07-08-2022 09:54 AM
04-16-2020 05:15 AM
06-06-2017 02:01 PM
