TRANSMISSION PROBLEM ?
Old Jun 14, 2012 | 06:51 PM
4DGA32's Avatar
something wrong with my transmission or is it like that? first time owning a automatic maxima, and when i put it in drive, it only goes to 20, then when i put it on 2 it goes only up to 40.
is there something wrong in the transmission ? do i have to replace it?
help pls
Old Jun 14, 2012 | 07:00 PM
FreshRichie's Avatar
you're saying your car doesn't go faster than 20 no matter how hard you press the gas on Drive? what are the RPMs?
Old Jun 14, 2012 | 07:03 PM
chrome91's Avatar
so its acting like a limiter at 20km/h and 40km/h? sounds like a sort of safe-mode
Old Jun 14, 2012 | 07:41 PM
rf97's Avatar
Ck tranny computer, could be burnt.
Old Jun 15, 2012 | 06:00 AM
njmaxseltd's Avatar
Check engine light on?
Does the bulb even light up when the ignition is turned to the on position?
Old Jun 15, 2012 | 02:56 PM
4DGA32's Avatar
yeah its weird and it stops at 3
Old Jun 15, 2012 | 02:57 PM
4DGA32's Avatar
yeah, im getting it checked out soon
Old Jun 15, 2012 | 03:08 PM
Amerikaner83's Avatar
Dumb q but you're putting it in D, right? Not 1, 2, or 3. But D.
Putting it in 1 gets you only first gear, 2 gets you first and second, D (with the o/d off warning light on the gauge cluster) gets you first, second, and third gears. D with no o/d off light) gets you all 4 gears in the auto.
How is the level and condition of trans fluid?
Old Jun 16, 2012 | 10:49 AM
maxinout93's Avatar
Make sure its in d drive,
Old Jun 16, 2012 | 11:33 AM
4DGA32's Avatar
yeah it is, it only goes up to 20...
Old Jun 16, 2012 | 11:35 AM
4DGA32's Avatar
yeah put it on D the limit is only 20 mph
Old Jun 16, 2012 | 05:57 PM
Trini Boom's Avatar
What year is your car? This sounds like a solenoid issue/valve body issue. Drain your tranny oil and remove pan and inspect. Pull tranny codes to see if we can find something there and report back.
Old Jun 21, 2012 | 12:30 PM
4DGA32's Avatar
98 and alright thank you!
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
