Backfire in intake
Old Jun 17, 2012 | 02:53 PM
MaxCanesFan's Avatar
Backfire in intake
I fixed my hard start problem, but now the car still wont start but I have a new issue that not sure how to figure out.
If I press the gas pedal down and attempt to start it I hear like a deep thunderish roar coming from the engine, and after a few attempts it backfires out of the intake. The tube coming from the throttle body/airfilter housing that leads to the front of the engine beside the battery puts out a big thump of air.
I have never known nor seen this car backfire before, and the fact that it if backfiring in the intake (still stock) has me totally confused. Any ideas?
BTW - the plugs are black (too rich) and I smell alot of fuel.
I have checked many things which finally got it to crank over. (Different post Maxima in Trouble)
Old Jun 18, 2012 | 01:38 PM
carsnwomen91's Avatar
If u kept cracking for a while maybe u could've flooded it? The roar is because youre cranking with the tb open... that's normal. Dunno about the backfire :S
Old Jun 18, 2012 | 01:43 PM
DennisMik's Avatar
Maybe you need to check the Engine Coolant Temperature sensor (ECTS). If all the plugs are black & wet, this is a possibility.
Old Jun 23, 2012 | 09:14 AM
any other thoughts on how to resolve or what to troubleshoot?
Old Jun 23, 2012 | 11:26 AM
asand1's Avatar
Valve timing may have jumped. Injected cars dont generally have enough fuel in the intake to backfire, could be a bad fuel pressure regulator leaking into the vacuum line.
Old Jun 23, 2012 | 01:26 PM
schmellyfart's Avatar
Any codes?
Old Jun 23, 2012 | 02:15 PM
wirelessdude04's Avatar
Check codes if any
Old Jun 25, 2012 | 08:56 AM
fat_kid's Avatar
make sure all of your intake piping is tight
Old Jun 26, 2012 | 05:00 PM
No codes and intake is tight.
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
