Test Pipe/Hi Flow Cat Concern...
Old Jun 27, 2012 | 03:50 PM
96MaXiclean's Avatar
This will fit a 99' right? I have a 2.5" Cattman cat-back and OBX V2s... Thanks!
http://www.ebay.com/itm/95-99-NISSAN...ht_5122wt_1214
Old Jun 27, 2012 | 04:00 PM
Amerikaner83's Avatar
description shows it fitting 95-97.
Is yoru 99 Cali or FED spec? The FED spec has the rear O2 sensor bung immediately after the main cat, not sure if it's a part of the cat or not.
Old Jun 27, 2012 | 04:10 PM
I'm Cali spec., I messaged the seller, but won't get a response until tomorrow, I don't see why not though... this doesn't have a bung, nor do I on my small cat.
Old Jun 27, 2012 | 04:15 PM
styliztik's Avatar
I'm pretty sure all 99's are Cali spec
Old Jun 27, 2012 | 04:20 PM
Nope.
My 99 is Fed.
Old Jun 27, 2012 | 05:20 PM
what are you guys thinking? fit?
Old Jun 27, 2012 | 07:54 PM
The seller responded faster than I thought, he says 'this will not pass smog, best regards'
I think what he's saying is it'll 'fit' but it wouldn't pass emissions, we all know this though...
Old Jun 27, 2012 | 08:21 PM
VQ'rInWLA's Avatar
why are you even giving a 2.25" diameter hfc the time of day? youd be bottlenecking your system.
Old Jun 28, 2012 | 03:44 PM
You are absolutely right...
Old Jun 28, 2012 | 04:24 PM
VQ'rInWLA's Avatar
Is a shop going to be installing for you? If thats the case, they should have magnaflow HFCs in stock and they can just weld flanges for you so its a direct fit.
Old Jun 28, 2012 | 05:51 PM
No a good friend of mine is gonna do it, I just can't find a 2.5"/2.5" test pipe, everything is 2.25"/2.5", should I just grab the 2.25/2.5?
Old Jun 28, 2012 | 06:11 PM
Rods03Max619's Avatar
Here you go a 2.5 one......Testpipe....
http://www.ebay.com/itm/95-99-MAXIMA...181449&vxp=mtr
Old Jun 28, 2012 | 06:36 PM
VQ'rInWLA's Avatar
Those dont line up properly. Flanges are off. Typical with eGay crap
Old Jun 28, 2012 | 06:37 PM
VQ'rInWLA's Avatar
If you want something bolt on, think about gutting your oem cat. Same results.
Old Jun 28, 2012 | 07:29 PM
VisciousMo's Avatar
If you don't care for a resonated test pipe. Go to a non franchise muffler shop and have them make you one. I got mine made and installed in < a hour.
Old Jun 28, 2012 | 07:52 PM
so the link with the 2.5 test pipe for ebay won't line up? 100% sure?
Old Jun 28, 2012 | 08:24 PM
Plenty people running them, if need a exact link got to PM Nmex where he got his from, same with the 240sx 3" test pipes line up with the Maximas, and off ebay.....
Old Jun 28, 2012 | 08:25 PM
Another good option....
Old Jun 28, 2012 | 08:27 PM
VQ'rInWLA's Avatar
A former local ordered the exact same one and when I went under to bolt it up, the flange was turned to the side. I had to take it to a shop to get it cut and rewelded the right way.
Old Jun 28, 2012 | 08:28 PM
VQ'rInWLA's Avatar
Yeah the 240 test pipes line up. But its 3". Hes running a 2.5 system
Old Jun 28, 2012 | 08:30 PM
VQ'rInWLA's Avatar
Exactly but I think OP is trying to avoid anymore hassle. He wants a bolt up pipe. I suggested the same up top.
Old Jun 28, 2012 | 08:35 PM
Was a example since typical egay, and plenty have got 2.5s off there also, but he has to search to see which ones worked.....
Old Jun 28, 2012 | 08:36 PM
VQ'rInWLA's Avatar
Yeah. And stay away from the megan. Theyre too long. They dont fit at all.
Old Jun 28, 2012 | 08:42 PM
I read those horror stories....
Old Jun 28, 2012 | 10:19 PM
schmellyfart's Avatar
^ I had no issues with mine.
Not all 240sx test pipes are 3".
Old Jun 29, 2012 | 02:32 AM
VQ'rInWLA's Avatar
Hmm guess its hit and miss then. The one Ive dealt with was a no go from the get go
Old Jun 29, 2012 | 09:21 AM
Yeah it really is hit or miss. I've dealt with two of the cheap $30 resonated 3" 240sx test pipes and they both leaked, and I think datdude is running one with no issues.
Same with OBX headers, some need the crossmember trimmed, some don't.
Old Jun 29, 2012 | 11:32 AM
VQ'rInWLA's Avatar
^ Definitely right about that one. Most everyone had to trim their xmember. Im one of the only ones that didnt have to. Close fit but clear enough to not be concerned. (.25" of clearance)
Old Jun 29, 2012 | 02:18 PM
I appreciate everyones feedback, I'm gonna take a shot in the dark with the 2.5" ebay pipe, if it doesn't work out I'll have Meineke fab me one, thank you guys.
Old Jun 29, 2012 | 03:58 PM
one other thing, the more I look at test pipes on ebay, 85% of the sellers' pictures flanges do not line up, is one side of the flanges fully movable, as if it could spin around?
here are some links if you've got a minute or two...
http://www.ebay.com/itm/95-99-MAXIMA...ht_3268wt_1344
http://www.ebay.com/itm/Nissan-Maxim...ht_4145wt_1344
http://www.ebay.com/itm/STAINLESS-RA...ht_4056wt_1344
http://www.ebay.com/itm/00-03-NISSAN...ht_3275wt_1110
Old Jun 29, 2012 | 04:15 PM
The flanges are supposed to be offest like that.
VQ was saying they were not properly constructed so the bolt holes on the flanges didn't mate with the rest of bolt holes on the surrounding exhaust parts.
Old Jun 29, 2012 | 04:22 PM
woooooooow, that is so lame, so basically anyone with a legit and true aftermarket header and cat-back exhaust is screwed, because these were clearly designed for an add-on piece to someones new purchase of a cat-back only...
Old Jun 29, 2012 | 04:34 PM
Worst case scenario one side dont line up, go to a shop cut off the flange, line it up, tack it, bring it down fully weld it out and put back in....
Old Jun 29, 2012 | 04:36 PM
No it should work with it also, Schmelly has aftermarket headers and exhaust, and plenty others do to.....
Old Jun 29, 2012 | 05:04 PM
The flanges are supposed to be like that, stock or not.
VQ is the outlier having an issue with that test pipe.
1% chance that the one you buy will not fit.
Old Jul 3, 2012 | 11:50 PM
Found this one also....2.5''
http://www.ebay.com/itm/RESONATOR-TE...94c9a5&vxp=mtr
TallTom
57
Oct 14, 2025 05:16 PM
tarun900
19
Dec 20, 2021 06:57 PM
maxinout93
Oct 31, 2015 02:04 AM
