98 Maxima stumbles in 5th gear at 2000 RPM, clutch was just replaced
Old Jul 3, 2012 | 08:47 PM
9Shenandoah's Avatar
My 98 Maxima stumbles in 5th gear at 2000 RPM. I just replaced the clutch last weekend and have not yet adjusted the freeplay. But that shouldn't make the engine stumble.
There were two long wires on a sensor at the back of the 5 speed transmission where the plastic harness connector broke when I removed the transmission. The plastic connector was located at the driver side engine mount . Does anyone know what sensor that is? This sensor is located in the area of the starter motor on the transmission, a bit lower and farther back.
I used spade lugs to reconnect them and they may not be making contact.
Can anyone tell me what's going on?
Old Jul 4, 2012 | 05:04 AM
njmaxseltd's Avatar
Have you checked for any stored error codes?
A stumble is usually a misfire. Check your work, make sure both crank sensors are clean. Check all electrical connections. Did you clean the mating surfaces when you put the tranny back in? Sounds like the sensor in question might be the speed sensor.
Old Jul 4, 2012 | 07:18 AM
thanks
Thanks, I will check the codes. maybe the ECU is relearning as I removed the battery for the clutch removal?
CRizz
41
Jun 7, 2021 05:42 AM
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
jholley
Aug 11, 2015 09:38 AM
MikesChevelle
Aug 10, 2015 10:53 AM
