Y pipe install question?
Old Jun 28, 2012 | 10:14 AM
Zelout95's Avatar
I don't have a floor jack and I don't know of anyone who does that I can borrow. How much would a shop normally charge to install the Y pipe, because I don't want to get crushed by my car. I need to know because when I go into the shop I want to have an idea on what is a good deal. Thanks.
Old Jun 28, 2012 | 10:15 AM
Amerikaner83's Avatar
I was quoted 150 IIRC for installation of a Y pipe at a performance shop. Some places won't do it since it removes the OEM pre-cats.
You know, if you have a set of RAMPS you should be able to do it...
or better yet, go to the regional subforums and throw it out there, there's lots of folks in Cali that could probably help ya out
Old Jun 28, 2012 | 11:06 AM
Zelout95's Avatar
Do people in regional forums generally charge too? Depends on the person I guess. Thanks for pointing me in the right direction.
Old Jun 28, 2012 | 11:51 AM
tigersharkdude's Avatar
^^most likely anyone is going to charge you unless you personally know the person
Old Jun 28, 2012 | 03:35 PM
schmellyfart's Avatar
It would be cheaper to buy a jack and some stands, than to pay someone to install this and any future mods.
Old Jun 28, 2012 | 03:50 PM
GGENIUS's Avatar
just buy some ramps for like 30 bucks n call it a day
Old Jun 28, 2012 | 06:48 PM
infinimax96's Avatar
My max won't clear ramps. :P But seriously you could get a nice 3ton jack and stands for less than $150.
Most shops probably won't do it because you are removing emissions cats to install the new ypipe.
Old Jun 28, 2012 | 08:40 PM
Rods03Max619's Avatar
This......
Old Jun 28, 2012 | 10:15 PM
Yeah as far as ramps go, I barely cleared them on stock suspension.
Old Jun 29, 2012 | 04:41 AM
GGENIUS's Avatar
oh. im still on stock suspension and clear ramps. guess forget the ramp idea
Old Jun 29, 2012 | 08:52 AM
Grand_hustle17's Avatar
to the OP im not sure if ther is a harbor freight by you but here they sell the jack for 69.99 n stands for 29.99... both pay for themselves
Old Jun 29, 2012 | 09:02 AM
gatsugansu's Avatar
^+1.
Old Jun 29, 2012 | 05:04 PM
tothemax2003's Avatar
just remember that pesky bolt that is melted at the end of the rear cat what a pain in the ***
Old Jun 30, 2012 | 07:20 AM
gthirtymax's Avatar
Your header studs are going to be rusted. I have some available if you need them.
Old Jul 1, 2012 | 11:41 AM
Yeahhh I don't think so.
Old Jul 2, 2012 | 06:47 PM
Huh? I never had any melted bolts on my Cat. Rusted yes, but none melted..
Old Jul 5, 2012 | 11:35 AM
kel456's Avatar
to the op, if you don't have jack stands then you probably don't want to deal with the y-pipe. by now it's pretty tough to deal with those nuts. under the headers some nuts will be fused to the stud. it easy to remove but you need to unscrew it very slowly so you don't break off the stud. since stud n nuts are fused you should be prepare with new ones. 2 nuts connected to the cat are fused so you need to cut off those nuts.
auto shop will charge you $100. most people don't have heating tools otherwise it would be an easy job. propane torch will get you nowhere.
Old Jul 5, 2012 | 07:24 PM
carsnwomen91's Avatar
LOL
OP just get jack stands. Jack ur car up with stock emergency jack. Works for me, just takes a while longer to get it up hahaha
Old Jul 5, 2012 | 11:00 PM
thedwyer00's Avatar
For the cost of going to a shop, you can purchase ramps, jack, and stands. I have all three and they make working on the car sooo much easier. Drive up the ramps (place 12" 2x4's same direction as the ramps, about 6"up the ramp, to 6" off at the bottom reduces vertical angle to help clear front bumper) then use the jack to lift it up and secure it on jack stands.
JRod28
Dec 29, 2023 09:56 PM
Cotozic
Jun 28, 2017 08:01 PM
rbuswell
Nov 12, 2016 04:11 PM
stromm
Aug 27, 2015 04:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
