dies in reverse
Old Jul 2, 2012 | 03:31 PM
CautiousDriver's Avatar
dies in reverse
my friend has a 99 max and when he switches to reverse car stalls. he says it's very rare when it happens in drive. his is auto. i'm thinking it's his idle air control valve. no check engine lights , the mechanics he went to can't find anything. throwing money at it would be stupid without knowing what is broke. anyone had similar issues they were able to resolve. ? thanks for any advice
Old Jul 2, 2012 | 07:02 PM
Trini Boom's Avatar
Crankshaft POS harness has a short. Inspect the red wire for breakage where they bent the wire and taped it up.
Old Jul 2, 2012 | 09:36 PM
Shift_A32B's Avatar
Check for vacuum leaks.
Old Jul 3, 2012 | 04:44 AM
sounds legit. Will check that out. Once I find it
manual will show it?
I believe I good at this end but will recheck it as well
Old Jul 3, 2012 | 05:06 AM
njmaxseltd's Avatar
Clean the throttle body and IACV.
Verify the idle speed is set correctly.
Old Jul 3, 2012 | 09:35 AM
maxinout93's Avatar
I had a similar issue, on my 95. Would start right up and soon as i put it in reverse it would die and take a while to start bak up at times. I cleaned iac valve and throttle body and changed coolant temp sensor, and its been fine ever since.
Old Jul 3, 2012 | 10:16 PM
That would be via little nut near the throttle cable
Old Jul 26, 2012 | 06:46 AM
Guys his iacv sensor has a Mitsubishi logo on it. Do we have a part that has that logo? To me doesn't sound right and that might be the priblem. What do you guys think
Old Jul 26, 2012 | 08:08 AM
asand1's Avatar
Many of our electronics are made by Mitsubishi. They are actually the better supplier.
Old Jul 26, 2012 | 09:00 AM
Max_Gator's Avatar
Take a look at the rubber piece between the Maf and throttle body. Inspect it closely to see if it is cracked/broken somewhere.
Old Jul 26, 2012 | 02:17 PM
eddie982's Avatar
I had the same issue once in my 98 auto, turned out to be the neutral switch.
Old Jul 26, 2012 | 02:21 PM
AoD11's Avatar
A known problem with our cars is the ects. I just replaced mine a week ago and my problem h
as subsided.
James92SE
142
Jan 2, 2024 09:23 AM
maxima297
Sep 30, 2015 03:32 PM
viperboy
Sep 27, 2015 07:05 PM
lrb6805
Sep 17, 2015 04:49 PM
