high rpms in 1st gear(stick shift)
Hey i have a 95 maxima. I just started having this issue today, first of all my check engine light came on. So when I start the car, it starts very roughly, then the rpms will almost drop all the way down(I allways think its gonna stall..its a stick shift btw) but then they come back to normal. But when I put it into 1st gear, the rpms jump to about 16-1800 rpms. It also does this when I put it in reverse. But if I pop it back into neutral the rpms go back to normal.
Also, when im letting out the clutch into 1st, the rpms seem to even out.
Its weird also when I have the clutch IN, when i barley push it into 1st the rpms go up as if I were hitting the gas.
The car still runs fine...this just makes it feel wierd getting out of first gear.
Any suggestions on how to fix or what the problem is?
I'll bite on this...heres the direct link to how to check your code http://vbxmaxima.8m.com/ecu.html check it and report back...once you get the code, go here http://boredmder.com/ecucodes/index.php and plug the code in to see what it means. You're welcome
Ok I got the code(s).
0707- rear o2 sensor fault
0303 o2 sensor fault
0403- Throtle position sensor
0503- o2 sensor fault
Im pretty sure that throttle position sensor is what is giving me those high rpms, is that a hard fix?
Here is a diagram showing where it is
http://www.justanswer.com/uploads/bi...715_maxima.png
Here is what the tps itself looks like
http://ebay.alldiscountautoparts.com...10786240_l.jpg
Ok I fixed the problem with the tps sensor, and the wires were actually disconnected lol.
But now theres a new issue. Ever since those wires came loose and I reconnected them, my rpms arent very stable. Every time i push the clutch in to slow down, the rps will damn near drop to 300, and I can feel the car shake. Could this be from the o2 sensors being out?
My car actually stalled out when I was switching to 2nd gear, cause the rpms dropped all the way. And it seems to not be as bad after I drive for a second. Mostly when I first start it up
