Over heating
Old Jul 10, 2012 | 12:03 PM
benjie's Avatar
Over heating
So on Sunday, I got stuck in some traffic at an interchange between west side highway and the cross bronx expressway. AC is running nice and cold and as I am inching down the highway, I notice my temperature guage is reading close to the danger mark. I wind down the windows and turn off the ac and the guage starts going down even though i am still stuck in traffic. By the time I get off the high way, it's back down to the middle.
Things that have been changed recently. Waterpump, radiator (twice in 5 months). I purged the radiator and I am able to repeat the overheating. I have not changed the thermostat or the fans and they are what I suspect at the moment to be the likely candidates. I say thermostat as both fans are spinning. The one on the drivers side spins faster but not extremely faster than the other. The hoses seem extremely hot.
Any ideas as to what could be the cause? I am changing the thermostat tonight.
Old Jul 10, 2012 | 07:38 PM
Trini Boom's Avatar
The fan that isn't spinning as fast may need to get replaced. Also, when you replaced the radiator, did you flush the entire system? Was there sludge in there?
Old Jul 10, 2012 | 09:17 PM
styliztik's Avatar
did you also pressurize the system when you changed the radiator?
Old Jul 10, 2012 | 09:43 PM
benjie's Avatar
I did not flush. No sludge noticed when I change the radiator. I changed the thermostat tonight. Spent most of my time getting the old gasket off. Topped off the reservoir and let the car run with the ac on for about 40 minutes. So far the needle stayed right in the middle. The fan kicked in at full speed tonight so I'm guessing the fan is variable speed.
Old Jul 10, 2012 | 09:46 PM
benjie's Avatar
If by pressurize, you mean purge the air out of the system, then yes.
Old Jul 11, 2012 | 07:37 AM
cashoit's Avatar
prolly just a bad thermostat.
Old Jul 11, 2012 | 08:53 AM
njmaxseltd's Avatar
Thermostats fail in the open mode as they age causing a cold engine condition.
Both fans should spin on you 99 at the same speed at all times.
There are 2 fans speeds, normal and high. Normal fan speed, a/c on etc. up until the coolant gets up to about ~240 (somebody correct that figure if I'm off). At that point both fans will go up to high speed, they're pretty loud at that point too.
I have a feeling one of your fans is not operating correctly.
Old Jul 11, 2012 | 11:38 AM
benjie's Avatar
I will keep an eye on it.
Question, can I change just one fan or are they sold as a set?
Old Jul 18, 2012 | 11:43 AM
benjie's Avatar
So yesterday, I pulled into the back yard with ac on. Stayed in the car just to see what would happen as it had been running good. The guage started to climb. Popped the hood and the fan on the right was not spinning. Tapped the housing for the fan motor with a screwdriver and it started working. Verified voltage on the white with blue stripe and white with black stripe wires on the harness. So NJMAX and Trini, you were correct. I already ordered the fan and I'm waiting for it to come in.
Just for verification, which fan is considered the Condenser fan? I would assume it's the one on the right but the AC is still running cold even with the fan on the right not spinning.
Old Jul 18, 2012 | 05:12 PM
Trini Boom's Avatar
On most cars, sitting inside the car, the left fan is considered the condenser fan but for pur cars, not only one turns on, they both come on with AC running or not.
Old Jul 19, 2012 | 06:02 PM
CMax03's Avatar
Good find Benjie.....Are you that same benjie from the 70's?
Old Jul 19, 2012 | 06:07 PM
CMax03's Avatar
I guess not your names are spelled different......I was gonna ask for your autograph! LOL....just joking around.....but your name brings back memories of one of my favorite Hollywood canines....
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
captchaos
Mar 15, 2016 12:18 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
